- 29 Dec 2014
- The "North"
Hello everyone, after working hard I've built up some capital so I have decided to build a fully hardline watercooled computer. This will be my first project on the forum.
As the title suggests I am going to use clear tubing and clear coolant. My inspiration for the build was that my current computer is a bit lacking and I love the new builds using a monochrome theme as it looks much cleaner and simpler than the usual red rigs. (Not that there is anything wrong with red computers as I own one myself) I also wanted change and with the release of X99 & DDR4 with their competitive pricing it seemed foolish not to invest in a new computer. With this I also wanted to try my hand at the stylish and clean look that hardline piping has as it looks fantastic on the builds I've seen here
Components List
Motherboard: Asus X99-S Intel X99 (Socket 2011) DDR4 ATX Motherboard
CPU: Intel 5820K 3.30GHz (Haswell-E) Socket LGA2011-V3 Processor
GPU: TBD
PSU: EVGA SuperNova 1000W '80 Plus Platinum' Modular Power Supply
RAM: Corsair Dominator Platinum 16GB (4x4GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit
Case: Phanteks Enthoo Luxe Full Tower Case
SSD: Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive
Watercooling Parts
Reservoir & Pump: EK Water Blocks EK-XRES 140 D5 PWM
Tubing: 13mm Primochill Acrylic or PETG (TBD)
Fittings: PrimoChill Revolver Compression Fittings (Black or White TBD)
Radiators: XSPC EX360 120mm Radiator & XSPC EX240 120mm Radiator
Fans: 5x Corsair SP120 Quiet Series High Pressure Low Noise PWM
So far here is my idea of tubing runs:
And a more detailed image:
