- 18 Mar 2012
- Eastbourne
can I have a link to 15.20 please
I put it in the driver thread
It's interesting how the Fury wins every test and then loses every test once both cards are overclocked.
http://videocardz.com/?p=56728
The Fury is only overclocked by 100mhz from what AMD said. We don't know what the gtx980ti overclock is. It could be way higher but we should know better when decent overclockers get a hold of them and add some voltage. Memory overclocking is going to be interesting as well.
Looks like he made a mistake
Yup, AMDs back!![]()
Not me, that's original AMD chart![]()
Opps sorry, now corrected![]()
it's funny though as nutella and others who were cherry picking the witcher results claiming improved tesselation isn't due to clocks, or memory timings.
Forgot to mention this clock for clock page.
Do you often double tessellation performance with a 50mhz clock increase? Just curious.
The tessellation game settings are different to the clock to clock settings. Due to...testing different things. Just a pointer.
You referenced it here in this thread, not me. And referanced yourself posting a 3 series link in a fiji topic yet are complaining to me for being off topic?nutella this is a nightmare as it's over 3 different threads, it shouldn't really be in here as it's fiji.
it's still not an apples for apples test like it is when they did the clock for clock test. Their turning up all the settings apples for apples test is unfair as it doesn't have equal clocks on the 290x and 390x, they should have tested a 290x 8gb and clock for clock.
Also in other games the apples to apples (but not clocks tests) the variance in fps in my opinion is just demonstrative of just clock speed differences. But i don't trust hardocp either.
Overclock Performance Table
WhyCry: This chart has an error, the right column is not 980 Ti, but overclocked Fury X. If you don’t believe check benchmark settings, 980 Ti does not support Mantle.
I also notice another in the main bench chart. I've circled both in red.
Obviously something is slightly amiss, as clearly the 980ti does not support mantle and Whycry reckons it not even suppose to say 980ti in the right hand column of the overclock performance chart. Quite what is up remains to be seen.
as per your second paragraph... you are saying a 50mhz increase and more RAM doubles tessellation performance. despite us not seeing this effect on 8GB 290x's? (overclocked or otherwise)
on your 3rd... it might be a driver difference just for the witcher. it might be the 390x's "tweaks". All I ever said was it was interesting and might point to some changes.
Ive got it now, they are both Fury X, the left column is Fury X @ stock, and the right column is the Fury X Overclocked.![]()
It's 100 mhz and 600mhz on the ram with suspect testing and driver difference. You provided the link and didn't mention the minimal difference in other games, or the clock for clock testing so i'm making it aware too fella.
