Yes we are one company but if you buy from them you return to them, not us.![]()
I've check the prices with the german partner site, they seem great. Do any of you get hit with import duty costs on the way in?
They also have the G1 TI cards IN STOCK!!
They also have the G1 TI cards IN STOCK!!![]()
There are no import duties within the European Union.
Wow that's brilliant! think i'll order now save myself over £65
It's the OCUk brand. BTW, max temps according to GPU-Z are 85 degrees C - isn't that quite high?
No, if you read every other GTX 980Ti reference review you will see that nVidia set the target temperature to 84 degrees celcius to get the max performance out of GPU Boost 2.0.
Edit: That cable braiding on the PCIe cables look nice. I'm still annoyed the EVGA Supernovas come with red PCIe cables![]()
EVGA Sell other colours.
Ugh, just had a look. €80 for some white or black cables. They don't just sell the PCIe ones.![]()
You have 3 reference cooler cards in SLI now right? Please let me know what max temps are like while gaming and during Firestrike.
Still not made up my mind on getting a 3rd card.
Also some FPS number for Witcher 3 at 1440p Ultra with Hairworks would be much appreciated.
Have another look mate.
1600W G2/P2/T2 Black Additional Power Supply Cable Set (Individually Sleeved)
$29
- 2 x 6+2pin PCI-E VGA Cables
- 1 x 6+2pin + 6pin PCI-E VGA Cables
- 1 x 3 Molex Cable
The cards run at the set target temperature as set by nVidia to 84 degrees celcius. That's the hottest they get during gaming and Unigine Heaven 4.0 loop. In 3Dmark Fire Strike (Extreme and Ultra 4K) they run cooler.
I have them overclocked from 1000@1250MHz GPU (base clock) and 1753@1945MHz Vram.
