They already leaked the reviewer's guide and the teardown... I'd say that's pretty good leakage.![]()
It wasn't leaked. AMD allowed them to release it early.
I think the fury x results are impressive but what people seem to be missing is the new drivers have given 390x and 290x cards a 10 to 20% boost in games.
Hopefully Fury's drivers are "on point"
some weird shiet is going on lol, now ppl blame AMD for a TOO GOOD of a Driver, live and learn![]()
probable shrink as well?
Something doesn't seem right about the benchmark numbers that were released, I'm currently playing Sleeping Dogs so thought I'd compare numbers.
Read the thread...
I did...
Care to point out what I missed ?
Considering a 980 Ti and Titan X are pretty damn close to each other performance wise I can't see these numbers being correct.
its called off topic.
your about to recive a suspension if you continue.
dont people read forum rules here?
WhyCry: This chart has an error, the right column is not 980 Ti, but overclocked Fury X. If you don’t believe check benchmark settings, 980 Ti does not support Mantle.
Off topic and suspension ? Didn't realize things got so police state and nazi like around here.
taking it personal? off topic is off topic however you phrase it.
adding that comment shows no concern either for the forum rules or mods.
I already gave you the proper answer, buy Fury x run it in your machine compare really simple.
I just saw something interesting:
http://www.amkor.com/go/tsv
Look at the GPU section, that appears to be an interposer with 2 GPUs on it? Amkor are the company who produced the interposer for AMD. I believe it is also possible to make them bigger than the reticle size of the lithography apparatus (~650mm2), either by "stitching" or some other means. Here is a patent I found in google from Xilinx published this year:
https://www.google.com.ar/patents/US8957512
So could we see multiple high-end GPUs on the same silicon?
So in theory we could have 4 Fiji GPU's on 1 x PCB if we could have 2 GPU's per silicon die thing majiggy ?
Imagine the power, 34 TFLOPS![]()
Yup, the interposer is made of silicon so if the chips are connected through that it's like being on the same die, very fast. Perhaps they can even figure out a way to connect all 4 without a PLX chip. Obviously it would be quite a feat of engineering and managing the heat would probably require liquid cooling but it seems possible in the next few years or so.
