It's not just the bandwidth but also the bus width being much much wider than traditional GDDR5 set ups.
4096-bit vs 384/512.
That's a massive chunk of data that can be pushed through up to 8 times faster than GDDR5.
gddr5 and HBM operates a bit differently. cant use the same logic for two different ways the tech operates8 times faster?
See, this is the bit that annoys me.
Wider bus, lower clock speed. The two are interchangeable. A 512bit bus at 8GT/s would be the same as Fury X's 4096bit bus at 1GT/s.
Well, if you think about all the power this card uses at stock but with a 50c stock peak load was it? That extra power could well go to the core. have a feeling these will be in range of 1500mhz core clocks. Just wondering what will be the limitation, power draw or thermals.
So the sarcasm wasn't needed.
Can the memory actually be oc'ed in the first place or does it need to be static should be the question asked.
For all we know at this moment in time regarding oc'ing core/memory-integration...ie nothing, perhaps wait a week until the tech bumph comes out-it's not rocket science.
Honestly don't know if your taking the hit n miss with boom there(never mind the reasoning for the thread-but benefit of the doubt and all that).![]()
I think it's either one of two things. It will be to do with degradation, it will likely get warm as you suggest. That, or it is likely performance related. There is probably a great deal of error correction in HBM.
8 times faster?
We have a 512bit bus at 6GT/s (390x) and we have a 384bit bus at 7GT/s (oc's to 8GT easily) in 980ti/TX.
Fury is faster, but it's 33% faster, not 800% faster.
PCIe 3.0 x4 is the same speed as PCIe 1.0 x16. PCIe 1.0 x16 is wider, 3.0 x4 faster. They are the same though.
IF either has an advantage, it's PCIe 3.0 (narrow, fast) not 1.0 (wide, slow) as for small packets the latency is lower.
Doesn't really bother me, only got my core overclocked on my 290, memory didn't seem to make much difference, so just put it back to stock and left it.
This has already been mentioned
So what?
Everything discussed in the thread is simply assumption and will be clarified on release.![]()
I'll be honest comming from some one who favors AMD more at the moment (Though i go where the best performance for my money is)
From the statement AMD made about the card being a overclockers dream im kinda gutted about the memory being locked down if this is true. And scratching my head to why they would call it a overclockers dream card. But at the same time i'm thinking do we really need anymore bandwidth from the vram?
I saw little performance increase from overclocking the vram on my 290x and i think AMDMatt (LtMatt back then) did a thread showing the effects of overclocking the memory had on the 290 series and it was hardly noticeable. He said that the best gains were from overclocking the core. This could be exactly the same case with the fury x and with the HBM modules being next to the core, just a 25mhz clock bump is quite substantial. People could overclock their memory more than they realize and break their cards. If there is more than enough bandwidth this might be why there are little gains from overclocking the memory and locked it down.
I'm sure AMD did it with good reasoning. But im going to wait and see anyways as im sure you can still overclock the memory if you really wanted to in the bios.
While on the surface that may be true, you've missed out on vital part of it all.
There is no memory controller or length interconnects connecting the VRAM to the GPU.
It's literally on top of the GPU so latency will be minimal if any at all, that alone can drastically alter the available speed. It's almost like comparing a HDD to SSD, they both can have the same storage capacity but one is just faster at accessing it than the other.
