- 29 Aug 2010
- Cornwall
Not sure if this should go here or in the monitors section...
I think it was at E3 that AMD started talk of VR in connection with the Fury X.
So I'm thinking, what is everyone's thoughts on VR?
Are you looking forward to it?
Will it last or is it another fad like 3D seemed to be?
Also, do we think it will have any effect on the development of GPUs going forward?
Needing to display the image twice (once for each eye) at a decent framerate is going to be demanding. Counter to that though is the fact that resolutions will probably go down as the technology probably won't be doing 4K for each eye for a while. Plus, I believe with the Oculus Rift they say you need something like 72fps in each eye to be smooth, which is higher than current 4K panels.
How will this work for people with visual disabilities? Will this stop VR becoming anything more than an extra?
