This bit...
...makes me think you will need to use your existing key at some point. The TP has a key in it, so I wonder if the TP key will not activate the RTM version, and will prompt you to enter your existing key instead? I.e. all TP installs will update to RTM, but it won't necessarily activate.
Well no it's quite clear. It's even in the line before your highlight.
do it's activated, so then you just clean install. Is anyone who did a clean install of w10 preview not activated?you will receive the Windows 10 final release build and remain activated
I posted earlier about the Nvidia driver for Windows 10. In build 10130 it was horrendous in games, I had to un-install it. Yet in build 10134, I can't fault it.
Pthanks, think I'll carry on waiting, I'm away for 10days anyway. So not much point rafting about.
