Doesn't look like you get the same amount/effect as consoles though:
So then if people are saying that they have the rain effects on pc just like the consoles (although afaic, it doesn't look as good), are people using the gameworks rain effects? If so, what happens if you disable it? Bare in mind that the consoles don't have gameworks...
Yup, this game is truly borked on PC
It's amazing on PS4 though !
I'm Batman.
.Ok, so what you're saying is that the lower resolution gifs are biased against the PC image???? How so?
The compression will affect both equally given that they are both the same resolution (at least they look similar in terms of sharpness/clarity, happy for someone to provide the individual images so that I can check the res.), if the gif is lowering the quality of the PC shot, then it would be diminishing the quality of the PS4 shot to the same extent. Regardless, it doesn't explain the missing rain and AO effects which are independent of resolution...
Of course, there's nothing to prevent you from providing pictorial evidence to the contrary.
Also, this isn't a pre-alpha version but the final release version.
And yup, still denying the witcher 3 graphics downgrade, once again care to provide proof against all the other media sites evidence?
http://psgetalife.com/2015/05/16/yet-another-downgrade-the-witcher-3/
Where is gregster these days? Haven't seen him around for a while?
But well done!
In the doghouse for a while.
He'll soon be back. You missing him?
I see you're still sore because someone disagreed with you about the Fury Nano being an overclocker / watercooler's dream (as it's on a minute PCB with a 175W TDP that's specifically not designed with this in mind - and which the Fury / Fury X specifically are).
There, as here, you just got angry instead of providing any form of counter-argument whatsoever.
