Cheers Matt!
Is the fan placement ok too? This is my first liquid cooled anything so am a bit wary
Thanks!
Perfect for your setup.
Cheers Matt!
Thanks!
Cheers Matt!
Thanks!
Perfect for your setup.![]()
of them to mount!
) could I just use mini Dp to normal size Dp adapters?You really should have it either front, bottom or back.. Reason top shouldn't be intake is because hot air rises so you be just sucking in warm air.
I thought it had to be above the card and the leads coming down? Should I move it right to near the optical bay area?
They no harm in what you doing. Am just stating what should be done but they is no reason why you couldn't run it like you have.
Test temps and go from there. From reviews I think you expecting around 50-60c range under load.
AMDMatt what drivers should people use if they are running win 10 preview?
From the MSI afterburner support forum, seems they will be on it as soon as they can - but expect a wait for voltage adjustment. It will give a chance for stock to stabilise & the initial rush to settle down.
few weeks, sweet mother of god.
always been like that with unwinder, MSI send him cards and he does the work.
