The Fury(X) Fiji Owners Thread
Just wanted to post a quick thanks for those of you that took the day one plunge and are posting pics and results. :)
Little bit jealous if I'm honest. :o
Still tempted to get one of these but as it looks like I'll need to wait a bit longer for stock - and prices - to settle, I'm probably going to wait until the Fury launch to see how it all shakes out.
Also hoping a DP to HDMI2.0 adapter is out by then that works ok and at a reasonable price, as it's still a factor for me.
Thief
4K Max Settings
Mantle
4x FuryX @1125/500Mhz
Swoon!
This please, at proper Ultra. So Hairworks and HBAO+ on.
Also Witcher 3 at 1440p maxed please.
I like to see hairworks on vs off at the same settings also :p.
I'm after 60fps 4k max settings hairworks off, I'd like to know if two cards can achieve that comfortably.
Has anyone tested the fury x on windows 10 yet? Would definitely like to see some Dx12 benchmarks as well as if the drivers for win 10 make a difference (many games run better under win 10 on amd hardware).
I could not find any drivers to get the card working in windows 10, so I have removed windows 10 and gone back to 8.1.
It would be nice if they had some driver support, have to be patient I guess.
Avg FPS: 133.7
No **** Sherlock!
That's 4 fps faster than 4 x Titan Xs using DX11.
I think what's far more impressive is the minimums of nearly 90fps.
Best hope those 4K freesync monitors have freesync ranges over Asus's 90Hz (and that 4K monitors become available in greater than 60Hz varieties...)
EDIT: Actually it looks like Kaap managed over 90fps minimums at 4K on his 290Xs, so that's not new either... ignore me!
Allegedly they are provided through windows update in the 10130-fast build - there is nothing downloadable.
I have a CoolerMaster Pump, it doesn't make any noise at all, its completely silent. its broken................ HA! :p
Can anyone confirm or deny that Fury X, and Fiji in general WILL support PNP eyefinity similar to how tonga does? I have wanted that feature for... well... almost a decade now, ever since eyefinity first came out I knew I wanted PNP... was so sad to see in the latest driver only tonga supported it.
