well benq have fixed the monitor so a 2730Z is on the cards again or I sell up and buy a fury profreesync or 980t and gsync.
AMDMatt,
Any chance you could have a word with someone about the flicking issue on AOC monitors?
Mines going crazy with this Fury x but only at 60hz, 30hz it's perfect.
Monitor is AOC U2868PQU
Drivers are 15:15
Tried downloading the modded ones from guru 3d but when I try installing them half the software is missing, just CCC and CIM are there
Humbug the grenada silicon is exactly the same as hawaii. The differences is on the pcb,the memory timings and the new drivers.
Wrong, first question in this interview.
I see you trust their PR. I love amd gpus but i know my things. Nothing changed inside the die. It use exactly the same core as hawaii. Grenada is not gcn 1.2
There's been many places saying the physical chip isn't exactly the same. Even pc per mentioned it.
Just tried them just now and working excellent. Everything on Ultra (hairworks off) and its sitting at 60fps.
Cheers!
If your talking about it being a 290X rebox it just isn't.
The 390X more often than not monsters the 290X, and i do mean monsters, its right up there trading blows with the GTX 980.
It might not be GCN 1.2, i don't think AMD go by such numbers its just GCN, but i do think it shares a lot in common with the 285, dubbed GCN 1.2.
Just have a look at this http://forums.overclockers.co.uk/showpost.php?p=28232919&postcount=6439
Serious question
Does the 295 x2 work with freesync yet?
Check this.
http://www.pcgameshardware.de/AMD-Radeon-Grafikkarte-255597/Specials/Radeon-R9-390X-Test-1162303/
Go to the tess tests
Probably they used the new 28nm HPC+ process. Still the bios that i checked for the 390x is exactly the same as the 290x just with new timings. You can even flash a 290x bios to a 390x. And you cant jump to gcn 1.2 that simply. Tonga die is way different in configuration vs a hawaii one.
Well thats one, here are the first 4 i pulled from Google all of which confirm what i just tested.
http://www.guru3d.com/articles-pages/msi-radeon-r9-390x-gaming-8g-oc-review,18.html
http://www.overclock3d.net/reviews/gpu_displays/msi_r9_390x_gaming_8g_review/11
http://hexus.net/tech/reviews/graphics/84194-sapphire-radeon-r9-390x-tri-x/?page=5
https://www.techpowerup.com/reviews/MSI/R9_390X_Gaming/11.html
