My amp does 1470 on the core 8000mhz on the memory.
Though thinking about this if the memory contributes to the tdp limit it might be worth leaving memory at stock to give the core more tdp room to boost.
What voltage you running for that?
Im considering changing my order from the evga hybrid to the msi 980ti. Should i go ahead or will it be worth the wait?
Hey Varkanoid how is the Samsung U28D590 you have compared I was looking at one of them but thought the acer with g-sync was a good idea when I bought it from looking at the recent reviews on the shop page. Looks like I was so wrong.
Thanks very much for the quick update Ben, appreciated.
EDIT: yeah sorry I didn't get an email notification and didn't look through manually, apologies.
My MSI Gaming can go ~1550 if it doesn't throttle from temps. This case doesn't provide the most efficient airflow. I need to know how to do this bios thing![]()
Hi
Next small incoming to OCUK will be before 7th July.
Ben
Mine seems to of started to have some issues. Was absolutely flawless Friday and Saturday but today I have noticed a lot of problems particularly in BF4 and GTAV.
In GTA the frames keep dropping to single figures where as before I was getting rock solid 60 with vsync. Went onto BF4 earlier and I was struggling to maintain 70fps on 48+ player servers. Although I did have a go at BF4 CTE on friday and was easily well over 100fps on dragon valley.
The only thing I did change was the dynamic super resolution option to give that a go. Since turned it off but the problems persist. Any ideas?
Hi Ben,
Is this for the Hybrid cards? Any idea how many are expected?
Cheers
I've always wondered how the different brands decide core speeds. The numbers are so specific (like 1278 or something). For example, why don't MSI just up there core the extra 25mhz to beat the G1?
