May i ask a question on this thread please if ok its a perfect thread to ask if ok
I think the OP is forgetting that you might not want to transcode your media which is where the NUC would come into play with a low power NAS (along with a whole host of other HTPC devices depending on your requirements).
I've got half decent server that stores all my media and does all the work transcoding when required. I also have a NUC as a HTPC in my front room but this doesn't receive any transcoded content, I use Kodi to just playback my media directly in full uncompressed glory. The reason I opted for the NUC was because there aren't many other devices that can pass through HD audio to my AV Receiver. I previously had a Raspberry Pi which worked fairly well bar the HD audio side.
Cokecan what Nuc do you have. I have an HTPC which i would be using as the server its an i5 4690. But after somethiung for the tv downstairs that will do 1080p mkv's over 20gig with HD audio and some 720's with DTS
I've got the i3 version (D34010) and it's just absolutely flawless. To be honest it's overkill and basically the same spec as my server (!). I was originally looking at one of the Celeron versions as you can now passthrough HD audio with them, but I managed to bag the i3 off eBay for around the same price as the Celeron's.
I rip all my Blurays using MakeMKV so most are 20GB + in size and they all play fine. To be honest they all played fine on my Raspberry Pi albeit with standard 5.1 passthrough instead![]()
a lot of my collection are 20gb plus. What Celeron would be ok for these sized files? Ive been quoted £360 and thats for everything. I dont mind paying that but if i can get something cheaper that would do the job that be great
I'm shopping around for a NUC myself at the moment and have similar requirements to yourself.
After a disastrous test with my E2180 CPU running Linux Mint last night, I'm more convinced than ever that a Celeron won't cut the mustard (Anything reliant on silverlight was a trying experience - Netflix would completely lock up the machine, Sky Go looked like garbage - both tasks it was fine with in Windows 8.1).
I'm really tempted by the 'HP Pavilion Mini 300-030na': i3-4025U, 4GB memory, 1TB HDD and Windows 8.1 for £350.
Could do with some more memory, but it has way more storage than I need and a Windows 8.1 license included - I'm pretty much sold. If it works out well as a media centre in the living room, I may very well get one to replace my E2180 secondary machine too.
It's bang on your budget, so it could very well be the box for you too.
