I don't understand why the EVGA is not as hyped, it has a beastly boost, cool and silent.
Mine is on boosting to 1470mhz core with only moving the power limit.
Same, i am not it hearing it at all.
So confused about the G1 noise, It's like hit or miss for everyone. On JayzTwoCents review it's completely silent.
What are you guys getting on the Bioshock Infinite benchmark with DX11, ULTRA + DDOF at 1080p/1440p?
Interested in OC scores so please post clocks![]()
It's almost like it's running openly in a cool room instead of being in a case or something.
Yes but I assume it was still done with fans @ 100%It's almost like it's running openly in a cool room instead of being in a case or something.
Just opened my Zotac Amp bios in Maxwell II Bios Tweaker and found the Max Table Clock at 1443. Interesting since when I try 1450 things go all screwy.
What are people seeing on other cards for the Max Table Clock?
EVGA-JacobF said:Originally Posted by iamhollywood5
Can you confirm the $699 price tag?
Confirmed. And more details tomorrow.
I'm in work atm but when I get home
Il run the bioshock benchmark at 1440p and post my results![]()
Ignore it. Your card will never use that table max. Check the voltage table required to reach table max and you will find 1281mv. Your card even with max volts will never reach 1281mv it will hit the tdp limit way before it and cant even provide 1281mv withoutva bios tweek as the max voltage is 1250mv.
So dont get hung up on that table unless you intend to flash your bios. I edited my zotac amp bios to tweek the tdp limit and even then i hit tdp new limit with the chip getting 1205mv.
Did get me an extra 30mhz though.
