Just ordered 2x EVGA 980 ti superclocks to replace my 2x EVGA 780 ti superclocks. Probably won't be able to accept delivery until monday though as I'm working saturday (one ever 2 months, sods law!)
Wish I could afford a 2nd one but saving for other upgrades at the moment.As you bought direct from Evga - don't they automatically register it to you?
Nice choice on the cardWish I could afford a 2nd one but saving for other upgrades at the moment.
What i am seeing is a rapidly climbing tdp once you hit 1450mhz. I guess this is what nvidia found. Will depend partly on the silicon but 325w tdp nets 1513mhz at 1205mv and starts hitting tdp again. Card can do 1250mv but never gets there due to tdp. Reason g1s go higher is in part to their higher tdp bios limit hence the 2x8pin connectors over the 6+8 on ref.
Going to try 350w probably and see if i get another 30mhz bump. I expect vrm temps are having effects here but you cant read their temps.
@Anchor yh i did use the correct phillips head screw
i really dont wanna resort to drilling. ive already tried the rubber band trick and that didnt do much. ive done one card all installed and done. its just the second one which is a pita! got two screws out just need another 6 out.
i'll try again later tonight, was proabably best not to do it with sweaty hands with this heat :/
if that fails ill look into that fast608 you recommended amigo. thanks all for the advice![]()
I am thinking of upgrading my set to a 4K one. Am i right in thinking that i can save FPS by disabling AA etc as it will have little effect on a 4K pixel count
The MSI Gaming 6G's fan at 100% sounds only a little bit louder than my 2 x 290 reference cards were at idle. Extremely impressed.
It boosted to 1341MHz straight out of the box with no tweaking. Managed to sustain a constant ~95 fps in BF4 @ 1440p Ultra.
Yup at 100% the rpm is much lower than competitor cards but it's still effective, excellent cooler.
They top notch coolers. I so wish you could get a gaming edition TX!
Just tried it at 100%, can just about hear it below the noise of my cpu cooler fans.Yup at 100% the rpm is much lower than competitor cards but it's still effective, excellent cooler.
Think I made the right choice
Got it to boost to 1461MHz in BF4 by adding 120MHz to the base clock. Increased the power limit to 109% in Afterburner (can't seem to get it any higher?) and didn't touch the voltage. TDP in GPU-Z showed 101.8% max.
My boost core is at 1567 @ + 175 so that buts my non-boost at 1392
Vram untouched atm
