If it's a recruiter then word as they will always remove your contact details so that the employer can't contact you direct.
I always send in docx because recruitment agency like to remove the contact info before handing it to clients so they cant bypass the agents.
Save as PDF, then print, rescan, at a slight angle, then send as BMP to fill up their inbox so no one else can send theirs.
Our recruiters convert PDF's to docx. so save me the hassle of them bothering me and send them in docx
If you send it as PDF then there is chance the formatting will get lost if you send it to a recruiter that doesn't/cant do a decent conversion.
No decent recruitment company will risk loosing business over doctoring CV's beyond removing personal details.
Unless of course its direct then pdf.
Applying via Recruiter - Word file, every time. Try not to have fancy formatting either, as this is really annoying. What we do with CVs is turn them into "our" format, take out a few details so you can't be contacted directly and change your wording up. If you do it with a PDF, it's a real hassle.
They do it so they can remove personal details from the CV, and they've also been known to "doctor" CV to BS people into an interview. This is especially common in IT.
I hate agents.
It's not necessarily especially common - as it can only lead to confusion on behalf of the client and the candidate when the "doctored" point is discussed during an interview.
In fact, in the decade I've worked in the profession, I've never heard of nor seen a CV doctored.
Lucky you. Plenty of the CVs I get sent have been doctored or are BS. The amount of times I've asked someone about something on their CV and they don't really have a clue on the subject is ridiculous.
Whether it's doctored, or just lying, I don't know.
