What HBM proves is current GPUs are not not bandwidth limited and GDDR5 can still beat an HBM solution.
I have been saying this for a long time.
A graphics card gets it's speed from the core not the memory.
Default settings in nvidia cp and bf4 ultra preset.
High Quality setting in cp and ultra preset.
Which card you using bud?
So, there's no shenanigans, it's just something on gregsters set up?
Unless I'm mistaken?
Standing in same spot this time
It seems to be the case. from bake's images. which drivers were you using Bake? the latest?
Positioning is everything!
Yeah definitely doesn't seem to be affected anywhere as bad as Greg. Although the pavement tiling on the right looks quite different to me.
The pavement is definitely sharper on high quality.
As said, it can be an advantage or disadvantage depending on how you look at it, however, for "performance" reviews, it isn't a fair test.
Any idea which settings should be used for AMD ccc?
I think IQ degradation should be the users choice.
Its fine to say with Nvidia vs AMD you have a choice between higher FPS with lower quality vs lower FPS with higher quality.
But if you set the same settings in the Game menu you expect to get those settings regardless of what vendor you are on.
If you want higher FPS then you degrade the quality yourself in the IQ menu, not have it forced upon you without your knowledge.
The performance Nvidia has in BF4 at least is by forcing a lesser quality than AMD. To me that is questionable cynical black arts sort of thing to do.
