I've had the notification for weeks (and signed up) but no sign of Windows 10 downloading...do I need to do anything?
we all got it, sign up, then w8 on release date, 29th july![]()
This will be fixed later this year. MS are rewriting the backend for the whole OneDrive sync system. The 'placeholder' files feature of 8.1 will eventually return in Win 10 and in a (hopefully) improved/more reliable form.
I've got three PC's, all with Windows 8.1 all fully up to date and no sign of Windows 10?
Meh no matter what i do i simply don't get the reservation, followed the link a couple of pages ago, ran scripts and all sorts.
My task scheduler is completely borked though so i'm tempted to do a new install and see how it goes.
I wonder if windows 7 theme file will work in windows 10 to give the aero effect I am going to try it in a vm shortly. Probably not but worth a try. Not sure how theme files are related throughout the system.
well Windows 10 didnt have the option to set colour title bars for windowed programs.
I have found a fix.
Step 1: Go to C:\Windows\Resources\Themes
Step 2: Copy the "aero" folder and paste it into the same Themes directory. Confirm the User Access Control request (UAC) and skip for all MSS files when prompted.
Step 3: Rename the "aero - Copy" folder to "windows" and confirm the UAC request if prompted.
Step 4: Go into the "windows" folder you just created and rename aero.msstyles to windows.msstyles. Confirm the UAC request.
Step 5: Go into the En-US folder and rename aero.msstyles.mui file to windows.msstyles.mui.
Step 6: Hit the back button twice and return to the Themes directory. Copy the aero file and place it on your desktop. Rename it to windows and open it with notepad.
Step 7: Under the [VisualStyles] section, find: Path=%ResourceDir%\Themes\Aero\Aero.msstyles
Step 8: Replace it with: Path=%ResourceDir%\Themes\windows\windows.msstyles
Step 9: Save it and then double click the file to enable colored titlebars!
Then once you have done this you need to run this:
%windir%\System32\rundll32.exe shell32.dll,Control_RunDLL desk.cpl,Advanced,@Advanced
Then you can set your colours etc like previous versions of windows.
If you buy a build from OC do you get it just installed or will you get a disk copy of Win10 as well to do a fresh install?
Those that are using windows 10 are you signing in with your hotmail account or a local account
I do the same on 8.1Microsoft account and local account... (3 accounts, 2 PC's, 2 Microsoft, 1 local, same on both "devices")Those that are using windows 10 are you signing in with your hotmail account or a local account
Outlook as I like to have everything synced automaticallyI do the same on 8.1
