Using a Gigabyte Z97X-Gaming G1, so things will be a bit different but translatable.
I'm trying to wrap my head around Uncore, VRIN and other stuff, there is a lot of reading to be done!
anyone underclocked for the summer?
Got mine running 4 GHz flat, turbo disabled, CPU Fan = 2.5 per C in BIOS (max variable setting)
SYSFAN 1 and 2 set to Full Speed Fixed 1214 RPM (front in and top out)
SYSFAN 3 (back exhaust) no control as its 4 pin molex
running 66c under load most days
Went to 72c on 'the hottest day'
HT still enabled don't really want to turn this off as it would technically make the CPU an i5
anything else I could do?
For one, keep your Vccin or total CPU voltage to 0.5v above Vcore. You can try 1.9 or 2.0v. 2.2 is uncharted territory, but for my personal overclock, a Vcore of 1.42 required Vccin of 2.15v for stability.
Thought i'd ask in here first before i start another thread
I've got a Z87 Asus Impact on the latest BIOS, 3 days ago i got a 4790K and swapped CPU's but the system wont boot, the Red LED for CPU comes on as soon as i switch it on!
Does this mean my CPU is DOA?
Setter, having trouble, just had a complete system shut down
It's passing stress testing but playing up
- It's only crashing in windows! Low voltage issue?
Have you reset the CMOS? I had a similar issue and i done that and it was all fine.
Just give up![]()
Leave it at 4.6, just wack the vcore up for benching and you'll be stable![]()
Remove CPU and check pins on motherboard, had a similar issue, turned out some thermal paste had got on to one of the pins, cleaned it off and good to go.
thought cpuz was inaccurate for vcore? do you not have any mobo manufacturer utils to read off voltages or try hwinfo.
I use fixed voltage myself, but on the board in sig I've had to up the SA, IOA and IOD voltages to 1.200. Any lower and I get crashes/freezing.
Yep, mine stays at 1.300v constantly.
Any idea what setting that could be in MSI to keep it at 1.300v constant? I'm wondering if it's a power state doing it.
