Caporegime
 - 8 Jul 2003
 - In a house
In those 3 vids above, the TX looks washed out compared to the Fury, massive difference.
I think on nearly all the side by side reviews the TitanX's textures look blurrier with less detail.
Vram usage is interesting, even on alien the fury is using less.
Only 70MB, I've seen bigger differences in benchmark runs with the same hardware and software, For example I've seen over 100MB differences when running valley 3 times on my rig with the TX![]()
  Mordor is tapping on the 2gb door in a few parts.Alien Isolation on the TX looks incredibly ashy and dull compared to the FX, Just curious but did you by chance leave the film grain filter on ? Both recorded with the same software/hardware ?
And alien isolation...also done on the capture card.
Greg, do a pair of recordings on the tx, one on dxtory one on the capture card![]()
kaap likes keeping us in suspense
The pic was done on a TX @2160p
What was interesting is when running the resolution the image is cleaner than either of the other 2 examples. This is using the native resolution of the monitor.
When I switch to 1080p (not the native resolution) the image quality takes a very big drop. I am not taking about the drop in sharpness going from 2160p to 1080p. The 1080p image actually looks a lot cloudier a bit like in Gregsters TX image but even worse. I tried to take a pic of it but it does not really compare to what you see on screen or in the video for that matter.
The point I am making is running a monitor at a non native resolution can effect the quality. Having said that the Fury X seems to cope with this better.
does running it borderless window make a difference to that?
but yeh something is messing up the colors for sure
its like night time in ark when u turn the gamma up![]()
