10163 due about now.
10192 already reported
10176
So it possible this is the RTM version! (?)
Im surprised nobody has started a poll to take bets on the RTM build number
10176
10200![]()
^^^^ Good spot, also there for the Z77 UD5H
10200![]()
10199
If I install a fresh (Legit) Windows 7, then update to Windows 10 latest preview (Through the upgrade option) should I receive the icon in the bottom right to reserve my Windows 10? As, I could just install W7 all fine, and wait till the 29th, but I'd rather not, I find W7 meh.
I'm currently on a fresh W10 Preview install, nuking my previous W8 install.
it'll just update. you won't se the reserve icon.
10200![]()
He's right.
The Final build will be delivered to anyone using the Insider Preview on or after the 29th. If you have upgraded your 7 install to the Preview with Windows Update then it will activate using your 7 license as your free upgrade. If you have clean installed the Preview it will activate as a Preview license and remain active only while you remain in the program.
10200![]()
10200![]()
Could well be, as I am sure I read somewhere... possibly on here, that it will end in 00 and be divisible by 16 (I think!)
Numbers = [600:700]*16;
PossibleBuildNumbers = Numbers(find((mod(Numbers,100))==0))
