Is a 980ti really overkill for 1080p
a lot of games get maxed out at 120fps @ 1080 for me with the gpu at like 50% usage so it barely gets above 55c lol
don't forget nvidia has DSR
you can game at 4k res downsampled by the gpu to 1920x1080
http://www.geforce.com/hardware/technology/dsr/technology
My max res is 1920x1080
My max hz is 144
The joys of DSR
I have one, but I'm running 1080p@120Hz.
GTAV with the advanced options turned up I average around 60-90fps depending on the area and what's going on, so there's a fair amount of wiggle room. I wouldn't consider buying a 980Ti a waste for 1080p.
It really depends what you want. I always go for flagship cards because they last longer before needing to be upgraded. You pay more up front but don't need to upgrade as soon :)
Exactly, 60-90 is barely overkill.
I've seen a few mention they're going Tri-SLI Titan X/980Ti for 1440p, I personally think that's a bit overkill but each to their own. I've got a 1080p monitor/tv but use Ultra HD DSR regularly and love it.
When you play games at 1080P on a Fury X like GTA V and you can't get playable frames, even when you haven't maxed out the settings, a 980Ti certainly isn't overkill :D
Not at all. In fact late next year i bet it will struggle in some of the latest games at 1080p with everything on.
I use a 980ti for 1080p, I was going to get a 980 to save some cash as I thought what's the point of having games running at more than 100fps on a 60hz screen but it turns out that with games like GTA V if you max out the graphics options you with be lucky to keep your frames above 60fps so I'm happy I paid the extra for the ti.
