Deleted member 66701
I'm getting closer, what are your voltage settings on you CPU to get to 4.9?
Thats a lot of volts!
Cheers
Could someone else with a Fury X run this please? I would like to see if my score is ok or not as it looks really quite low in comparison to others.
Not really - it posts and runs some benches @ 5ghz and 1.4v
http://img.photobucket.com/albums/v25/amigafan2003/5ghz_zpsca0ed0a1.png~original
Your CPU is the bottleneck but be proud, you smashed up my Fury X score![]()
Its 15% higher than a similar clocked 290X, fifteen percent. with 45% more Shaders and 60% more memory bandwidthWhy is your Fury X score so low? I would have expected a lot higher.
Currently the lowest 980Ti, and proud!... Not really though.
3943 score, GTX 980Ti @ 1560MHz/2000MHz, 353.49 drivers.
i5-3450 @ 3.5GHz
I think my CPU is the problem here..
Edit: I'm a little confused. My GPU-Z reads 1560MHz core (+181MHz in Afterburner) but Valley reads 1725MHz?
Edit again: Decided to do 2160p, same speeds as above. Score: 1345.
If you asked other Fury-X owners to post a result i suspect it will be the same, its not just this, Fury-X averages less than 20% better @ 1440P than a Hawaii XT in Games, something just isn't right with it.
