- 22 Mar 2009
And if you use this key, and then it later gets blacklisted, what happens?
Correct the key will be blacklisted on 29th July
No, u have to purchase one! (there is no need for product key if upgrade from windows 7 SP1, 8, 8.1)Forgive me if this has been asked and answered already.
On the 29th will MS allow us to download an ISO in order to do a fresh re-install? Yes
Also will we be given a product key?
Clean installs/ISO installs no longer activate. Only upgrades through Windows Update will work from now until release.
so is 10240 the RTM?, I no longer have the build details in the bottom right corner
That's annoying as need to install to a new ssd, guess just do windows 8 first then upgrade?
Build 10240 is preleased to RTM. Not final build. Say Microsoft.
Yes I understand there will be one more 'final' build released, but with no significant fixes - just mopping up.
no this isn't the final build... it's very near tho
You can't do that either any more. The download to get the little Enabler patch to allow Windows 10 to be installed over Windows 8.1 through Windows Update has also been removed.
I dont think there is any way to get a new install of Windows 10 working at the moment. Only upgrading an existing 10 Preview to RTM works.
Just to confirm (just tested on a vm), 10240 will not activate from a clean install with the following key: VK7JG-NPHTM-C97JM-9MPGT-3V66T
It's will activated if u using CMD as administrator with a special code keyword (can't put it here otherwise Microsoft will see it and find a way to BLOCK it)
Upgraded from an activated 10162 to 10240 and its still activated and running fine, it managed to cabbage my printer driver and got stuck in a loop of trying to download and install a new one, failing and then trying again... but ive manually installed a newer version directly from Samsung and its all now working fine.
Having the same problem...I shall keep waiting seems strange that I never received the 10166 update either....
I downloaded an ISO of 10240 and it installed fine and is running ok but fails to activate. I have tried my original key and a few from the web but it still fails to activate ?
I have upgraded from 8.1 to 10162 and then to 10240. 10162 was activated as normal ?
Any ideas anyone ?
and activated, turns out 10240 decided to disable IP4 settings, so was only connecting with IP6
