Mixing Memory
6 Jan 2013
Rollergirl
I ran it individually on each stick, should I run it with all 4 too?
should be ok if ran on each stick but I would run it again with all 4 in so you know everything is ok as if you ran it on each stick using the same slot on the mobo the other 3 slots on the mobo would not have been tested
