It causes stuttering, hows that useful?
It doesn't cause stuttering.
Windows takes a good 300-600mb of VRAM even in full screen, the driver simply allocates the windows dma memory to the last 512MB. Job done, the card is has a full 1GB more VRAM.
They did enable it lol They released a new updated driver in 15.7... Review was for 300 series why give out drivers for other GPUs that are not getting tested/reviewed ??
It makes no sense to add other GPUs into a press driver all you doing is adding more things that can go wrong...
Get your feedback from press release and then add that into already working driver builds hence 15.7 driver release.
Simple!
So, are the 290X/390X performing equally now? At same clocks of course.
Or was their definitely an architectural tweak?
Nvidia lied in their marketing for the product and didn't correct the mistake for months after launch.
only when users created a programme to highlight the flaw that was causing performance degradation and made it public did nvidia even admit it was an issue.
They designed a handicapped card and sold it like a full card blatantly misadvertising the gtx 970.
They cashed in while they rode the wave. End of
They was defo work on power efficiency on the 300 series... So the 300 series will Overclock much better. But clock for clock they shouldn't be much difference.
Hmm yeah, total coincidence that they released review drivers that just happen to include a big performance boost and they "accidentally" forgot to enable it on the 2** series when people at home could do that with a simple ini edit
What would happen if AMD did die though. nVidia especially will **** us over for years to come *cough* 8800 *cough*. Intel have been "reasonably" good with no real competition, but having NO competition? Who knows.
Ideally, we need AMD to have a "win" at some point and a third company join in the GPU-games. Bring back 3dfx![]()
It's a 256 bit card, it could and should just have normal 4GB VRAM like a GTX980 (Or, better example, like a GTX 770 etc does)
I don't know where you're getting this extra VRAM lark from.
It isn't a benefit.
I thought the issue lied with the bus itself not the VRAM . The 512mb was on something like a 32bit bus or something , not exactly sure but I don't think it was a straight memory issue
Pity GOogle aren't interested - could buy it with their pocket change given the company is worth another $65billion or so since a few days ago.
History rewrite attempt.
The point is they could have had a conventional 4GB VRAM card on a 256 bit bus.
There's no "Extra VRAM" gained etc.
You don't make money by throwing it into a black hole![]()
AMD is currently worth 1.5billion, a drop in the ocean for google and they could just make use of the patents to prevent apple getting litigious over something in the future
