Beasty, have you tried getting a x16 pcie extension and mounting the 2nd card somewhere else?
I've seen people mount the 2nd gpu at an angle as well, using a flex sli bridge .. Anything just to open up that gap a little
You can twist the pcie extension so you end up with the 2nd card upside down, and that might change what obstacles you have, for better or worse
Hi all, just posted a thread here in GH as i've just bought that funky new 4k Philips 40" screen.
http://forums.overclockers.co.uk/showthread.php?t=18682468
At the moment I have 2 x 7850 in crossfire....which is OK but I guess there's better. These 980TI's have caught my eye, never spent so much on a card before, £200 tops but hey, if splashing out....
I like the look of the Zotac ones....the AMP Extreme seems to be the most popular and is on offer this week. Is it worth the extra £70 over the normal one or are most people just overclocking them?
Just received my MSI 6G. So glad I RMA'd the Gigabyte G1.
Absolutely no coil whine, and even with an aggressive fan curve pushing 80% @ 60C the noise is much less than the G1, much less.
Very pleased. I've taken quite a few screen shots during my testing over the past while, so I'll try to find time to post details to help others who are trying to choose their next card.
Looking to upgrade my GTX 780. I'm sure it will fit in my 540 case but not sure about my motherboard. Due to it's size would it be fine on a Maxumus V Gene MB?
Just placed an order for the MSI 6G. Decided not to go with the Zotac, as I heard people were having problems with coil whine and the fans acting up.
G1's seem to be getting returned a lot wonder what the return rate is.
What seems to be the main issue with them being returned?
