Any card is susceptible to coil whine at extremely high fps, just some are more prone than others.
So not worth sending it back since it's just in menus? It's pretty ****ing annoying.
My 290 certainly didn't do it
My 290 certainly didn't do it![]()
Vsync solves that.
I am seriously thinking of this card, https://www.overclockers.co.uk/showproduct.php?prodid=GX-056-IN&groupid=701&catid=1914&subcat=1402
the air boss ultra, don't particularly like the look but it seems higher clocks than most and its now in my price range. Any comments.![]()
But VSync also adds latency. I've got a ROG Swift on it's way to me, will Gsync solve it too ?
Yes. Set a frame limit of 1 below your refresh rate using Afterburner for all games. Doing that will ensure that Vsync never gets used, and Gsync does its magic instead. You will also never reach a frame rate that induces coil whine.
Didn't think of Afterburner, if I just set a limit of 150 will that have any downsides ?
You can now turn off vsync entirely under the gsync options and set the frame limiter to the full 144, bam no input lag as gsync I completely off
Save £40 and buy the Zotac AMP Edition instead?
Mine boosts to 1265@stock & clocks to around 1430-1450core / 7700-7800mem, which are the same speeds as CEUOTC's AMP Edition from the last page.
( and typically it's now £10 cheaper than when I bought mine last Friday)
Any sag with that card in the case? Looks pretty beefy to say the least, much in the way of fan noise? Seen one review say its virtually silent and he had to get up to check if the fans were spinning.
Why buy a Gsync monitor and switch Gsync off?![]()
Typo, not gsync off, vsync off. There is now a separate option for having gsync on but vsync off.
ULMB![]()
Which takes me back to SLi solution I suppose - what's the current thinking for SLi 980tis? Reference design blower I guess - any of them better than any of the others or is it just price and warranty at that point?I don't think you'll get away with one card at that res if you want ultra across the board.
Yes because Gsync works best when below the refresh rate as it syncs the GPU and screen at the same Hz. It can't make your screen up its Hz but it can make your GPU match the screen Hz. This is why you set 1 below refresh rate, it ensures they are always syncing.
Actually, you should have game settings high enough that you shouldn't be able to achieve 1fps below refresh rate. That's why you bought a 1440p Gsync monitor.![]()
