The GTX 980 Ti owners thread.
22 Sep 2011
Portsmouth (Southsea)
what bios elmarko?
This one
Here is a modded BIOS with 425W power target:
- Based on the EVGA SC BIOS, no boost limit
- 350W default power target at 100%
- 425W max power target at 121%
http://www.overclock.net/t/1558645/official-nvidia-gtx-980-ti-owners-club - Using that bios my power limit never goes above 80% (which is about 270/290W) the default +10% is a little too really, it should be a stock +20% power & hardly anybody would need to flash the bios.
Obviously there is a risk, but I got sick of the power throttling causing my clocks to go all over the place.
@ Air I had 1445 stable
@ water 1475 stable (No power used for air coolers)
@ water /w bios 1525 stable (no power cap, but hitting volt caps now on one of the cards).
Both MSI 980ti Reference.
For SLI you can do reference, or two good aftermarket ones your happy with high fan speeds. I'd say the MSI G6 aftermarket cooler for SLI seems good , with a side panel fan to improve air flow.
SLI on air reference for me the killer was the noise, so it needs to be an air cooler you can stand @ 70/80%.
25 Oct 2007
Los Angeles
This one
I have the same card as you on custom water. Currently running 1400mhz @ stock volts. Is there a danger of using the said custom bios? How can you tell that you're hitting the volt and power caps?
22 Sep 2011
Updating the bios can always have a risk of turning the card into an expensive paperweight!.
Load up GPU-Z & under "Sensors" it will give you the perf cap reason, also monitor your power limit in MSI afterburner - if it's going to 110 often & the clocks reduce your hitting the limit.
If you can't get to the power limit & hitting other barriers this early then one of the cards may not be that great of an overclocker. I'd be surprised if your hitting the power limit at 1400 but all cards are different, what settings are you using in AB?.
25 Oct 2007
Los Angeles
Running max power, +0 volts and 220+ core and +400 memory if memory serves me correctly. Running a single card btw.
Man of Honour
OP
21 May 2012
Dalek flagship
Welcome and TROH updated.:)
The Roll of Honour.
Make MSI Gaming, majnu, Link, Date 23/07/2015
Make Zotac AMP Extreme, Frenzy, Link, Date 23/07/2015
Make Zotac AMP Edition, CEUOTC, Link, Date 22/07/2015
Make MSI Gaming, OvEr_KiLL, Link, Date 20/07/2015
Make MSI Gaming, anewhope, Link, Date 19/07/2015
Make MSI Gaming, KLM, Link, Date 17/07/2015
Make MSI Gaming, Devious, Link, Date 17/07/2015
Make EVGA SC ACX, Temp.sgk, Link, Date 16/07/2015
Make Zotac AMP Extreme, beasty54, Link, Date 16/07/2015
Make Zotac AMP Extreme, Yulaw, Link, Date 16/07/2015
Make Asus Strix, PurE GaminG, Link, Date 15/07/2015
Make Palit Super Jetstream, marcus2704, Link, Date 14/07/2015
Make Gigabyte G1, String, Link, Date 14/07/2015
Make Palit Super Jetstream, Spit, Link, Date 14/07/2015
Make Gigabyte G1, McShave, Link, Date 13/07/2015
Make MSI Gaming, Boomstick777, Link, Date 12/07/2015
Make Zotac AMP Extreme, beasty54, Link, Date 11/07/2015
Make EVGA Classified, kael13, Link, Date 11/07/2015
Make Zotac AMP Extreme, currob, Link, Date 10/07/2015
Make Zotac AMP Extreme, Metalface Mark, Link, Date 10/07/2015
Make Zotac AMP Extreme, razorpakk, Link, Date 09/07/2015
Make MSI Gaming, Mallers, Link, Date 09/07/2015
Make Gigabyte G1, Rowlii, Link, Date 09/07/2015
Make MSI V1, samcat, Link, Date 09/07/2015
Make MSI Gaming, Jeps, Link, Date 08/07/2015
Make EVGA Hybrid, F1aw1ess, Link, Date 07/07/2015
Make Zotac AMP Edition, sunn, Link, Date 06/07/2015
Make EVGA Hybrid, DVR, Link, Date 06/07/2015
Make MSI Gaming, Firefox35, Link, Date 05/07/2015
Make MSI Gaming, 40Four, Link, Date 03/07/2015
Make MSI Gaming, Ghosteh, Link, Date 03/07/2015
Make MSI Gaming, arknor, Link, Date 02/07/2015
Make Reference, amigafan2003, Link, Date 02/07/2015
Make Reference, savagesam117, Link, Date 01/07/2015
Make Gigabyte G1, Combat Fighter, Link, Date 01/07/2015
Make OcUK Tech Labs, NoobCannon, Link, Date 01/07/2015
Make EVGA Hybrid, Joe_Easy, Link, Date 01/07/2015
Make Inno3D Herculez, IceWind, Link, Date 01/07/2015
Make Gigabyte G1, Ashley Jordan, Link, Date 01/07/2015
Make Reference, colinmcr, Link, Date 30/06/2015
Make Gigabyte G1, Doco, Link, Date 30/06/2015
Make Zotac AMP Edition, digitalx, Link, Date 30/06/2015
Make Gigabyte G1, Robzere31, Link, Date 30/06/2015
Make Gigabyte G1, Jonahun, Link, Date 30/06/2015
Make MSI Gaming, Five.Stars, Link, Date 29/06/2015
Make Gigabyte G1, Fire_fly, Link, Date 29/06/2015
Make MSI Gaming, Radeon123, Link, Date 29/06/2015
Make MSI Gaming, setter, Link, Date 29/06/2015
Make Gigabyte G1, plazyma, Link, Date 29/06/2015
Make Gigabyte G1, rossiboy001, Link, Date 29/06/2015
Make Reference, toodoo9011, Link, Date 29/06/2015
Make Gigabyte G1, rootz, Link, Date 29/06/2015
Make EVGA Hydro Copper, dceightfive, Link, Date 29/06/2015
Make EVGA Hybrid, SaintJimmy, Link, Date 28/06/2015
Make MSI Gaming, Spokwiththeears, Link, Date 28/06/2015
Make Reference, goochinbuda, Link, Date 28/06/2015
Make Inno3D X3, Newu_boy, Link, Date 28/06/2015
Make MSI Gaming, Wyrdo, Link, Date 28/06/2015
Make MSI Gaming, gt11, Link, Date 27/06/2015
Make Zotac AMP Edition, DBT85, Link, Date 27/06/2015
Make Gigabyte G1, Rivod, Link, Date 27/06/2015
Make MSI Gaming, Milky1, Link, Date 27/06/2015
Make EVGA SC ACX, fornowagain, Link, Date 27/06/2015
Make Zotac AMP Edition, Angerer, Link, Date 27/06/2015
Make EVGA Hybrid, alexp999, Link, Date 27/06/2015
Make MSI Gaming, ubersonic, Link, Date 27/06/2015
Make MSI Gaming, lnoton, Link, Date 27/06/2015
Make Zotac AMP Edition, Type_R, Link, Date 27/06/2015
Make Reference, Wrxengland, Link, Date 27/06/2015
Make Zotac AMP Edition, agt, Link, Date 27/06/2015
Make EVGA SC ACX, Scramz, Link, Date 26/06/2015
Make Inno3D X3, Cavallino, Link, Date 26/06/2015
Make MSI Gaming, LauraLC, Link, Date 26/06/2015
Make Reference, Winnter, Link, Date 26/06/2015
Make Reference, Clov!s, Link, Date 26/06/2015
Make MSI Gaming, titaniumx3, Link, Date 26/06/2015
Make Zotac AMP Edition, PowerPie5000, Link, Date 26/06/2015
Make EVGA SC ACX, thefogo, Link, Date 26/06/2015
Make Zotac AMP Edition, mufc802, Link, Date 26/06/2015
Make EVGA SC ACX, GeneralD, Link, Date 26/06/2015
Make Zotac AMP Edition, Rossi~, Link, Date 26/06/2015
Make MSI Gaming, tyler_jrb, Link, Date 26/06/2015
Make Zotac AMP Edition, picnic, Link, Date 26/06/2015
Make MSI Gaming, DeanT77, Link, Date 26/06/2015
Make MSI Gaming, Brutos, Link, Date 26/06/2015
Make Zotac AMP Edition, Buck890, Link, Date 26/06/2015
Make MSI Gaming, se_vietboi, Link, Date 26/06/2015
Make Reference, Cottee, Link, Date 26/06/2015
Make EVGA SC ACX, ZeroG, Link, Date 26/06/2015
Make EVGA SC ACX, clone, Link, Date 25/06/2015
Make MSI Gaming, GiB, Link, Date 25/06/2015
Make Inno3D X3, rootz, Link, Date 25/06/2015
Make Inno3D X3, Khorvos, Link, Date 25/06/2015
Make Reference, amigafan2003, Link, Date 25/06/2015
Make Inno3D X3, theor14, Link, Date 25/06/2015
Make Inno3D X3, rickyjb, Link, Date 25/06/2015
Make Reference, floatindolphin, Link, Date 24/06/2015
Make Reference, eviljester91, Link, Date 23/06/2015
Make Reference, KillBoY_UK, Link, Date 23/06/2015
Make Gigabyte G1, Kered_Dub, Link, Date 23/06/2015
Make Gigabyte G1, Wrinkly, Link, Date 22/06/2015
Make Gigabyte G1, ronnie136, Link, Date 22/06/2015
Make Gigabyte G1, WHAT21A, Link, Date 22/06/2015
Make EVGA SC Ref, Divine Pain, Link, Date 22/06/2015
Make Gigabyte G1, AhadielGames, Link, Date 22/06/2015
Make Gigabyte G1, Shivji, Link, Date 20/06/2015
Make Reference, M1keMK, Link, Date 18/06/2015
Make EVGA SC ACX, ihatelag, Link, Date 18/06/2015
Make Reference, Diuz, Link, Date 18/06/2015
Make Reference, C3PO, Link, Date 18/06/2015
Make Reference, psychas, Link, Date 18/06/2015
Make Reference, MasterOC, Link, Date 18/06/2015
Make EVGA SC ACX, Malesu, Link, Date 17/06/2015
Make EVGA SC ACX, Mayh3M, Link, Date 17/06/2015
Make EVGA SC ACX, IT Troll, Link, Date 17/06/2015
Make EVGA SC Ref, jetpaczx, Link, Date 17/06/2015
Make Gigabyte G1 Gaming, Brutus, Link, Date 17/06/2015
Make Gigabyte G1 Gaming, youdsy, Link, Date 17/06/2015
Make Gigabyte G1 Gaming, HidYn, Link, Date 17/06/2015
Make Gigabyte G1 Gaming, Matthew89, Link, Date 17/06/2015
Make Gigabyte G1 Gaming, delpy8, Link, Date 17/06/2015
Make EVGA SC ACX, Axekickjack, Link, Date 17/06/2015
Make EVGA SC ACX, ArnieRambo, Link, Date 16/06/2015
Make EVGA SC ACX, agnes, Link, Date 16/06/2015
Make EVGA Hydro Copper, Giggz, Link, Date 16/06/2015
Make EVGA Hybrid, Muska, Link, Date 16/06/2015
Make EVGA Hybrid, is149, Link, Date 16/06/2015
Make Reference, The Mad One, Link, Date 15/06/2015
Make EVGA SC ACX, Valenni, Link, Date 15/06/2015
Make EVGA SC ACX, OldBoy75, Link, Date 15/06/2015
Make EVGA Hybrid, shiver, Link, Date 14/06/2015
Make Reference, ICEx21, Link, Date 14/06/2015
Make Reference, varkanoid, Link, Date 13/06/2015
Make EVGA SC ACX, JunglistE, Link, Date 13/06/2015
Make Reference, Gripen90, Link, Date 12/06/2015
Make Reference, Strife212, Link, Date 11/06/2015
Make Reference, saintdefender, Link, Date 11/06/2015
Make Reference, crazy8s, Link, Date 10/06/2015
Make Reference, Tom Martow, Link, Date 10/06/2015
Make Reference, rpggamesplayer, Link, Date 10/06/2015
Make Reference, toon_mad, Link, Date 10/06/2015
Make Reference, jjgreenwood, Link, Date 10/06/2015
Make Reference, Razor Time, Link, Date 10/06/2015
Make Reference, SeeNoWeevil, Link, Date 10/06/2015
Make Reference, RyanF, Link, Date 09/06/2015
Make Reference, roozor, Link, Date 09/06/2015
Make EVGA SC ACX, perosus, Link, Date 09/06/2015
Make Reference, ZombieDescartes, Link, Date 09/06/2015
Make Reference, Techen, Link, Date 08/06/2015
Make Reference, Rap1D, Link, Date 06/06/2015
Make Reference, khemist, Link, Date 06/06/2015
Make EVGA SC Ref, ciggybumly, Link, Date 05/06/2015
Make EVGA SC Ref, N19h7m4r3, Link, Date 04/06/2015
Make Reference, queeg, Link, Date 04/06/2015
Make Reference, abaddon, Link, Date 03/06/2015
Make Reference, Volv, Link, Date 03/06/2015
Make Reference, Larcwide, Link, Date 02/06/2015
Make Reference, a66as, Link, Date 02/06/2015
Make Reference, Angst, Link, Date 02/06/2015
Make Reference, RichardH754, Link, Date 02/06/2015
Make Reference, Phixsator, Link, Date 01/06/2015
Make Reference, Tommy_Here, Link, Date 01/06/2015
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your 980 Ti.​
25 Oct 2007
Los Angeles
Here are my settings
In BF4 I am constantly hitting my voltage limit. I tried going to max voltage with the same settings and the core clock went up to 1430 however there was still a '1' for the voltage limit. Any thoughts?
Caporegime
18 Oct 2002
Ireland
Has anyone with an amp edition opened up the zotac logo near the top? Looks like it should illuminate and seems to only do it on the xtreme edition. Wonder if theres anything underneath the plate that can be connected to illuminate it? From pics at least it looks like its a lens of some type for an led.
11 Jan 2011
What kind of temps are you guys getting when gaming with 1450Mhz+?
And what fan speeds/fan curves are you using?
Just want to compare mine and see if it's running ok.
Mines 1474Mhz and temps reach 73-75 with BF4, 77 with Witcher 3 and 77 with Dying Light.
Fan speed around 75%-80%
Permabanned
8 Jan 2010
UK
Yep, "Twirlywoos that would be brilliant" is a great name!
Be sure to post your request in the General Discussion forum, for best results.
Never :D
Can't believe how nice and quiet this card is compared to the 670 Windforce SLI I had before. 67 degrees c is when I notice the cards start to throttle down by 12Mhz.
So far I've maxed out the power limit which is 109 for my card and increased the core clock only (not touched memory yet) by +160 which gives 1514Mhz and it is stable in Valley and BF4 sessions. For those who are ASIC conscious my card is 74.5%
How do I measure VRM temps also? I want to get useful information before I wack the Kraken G10 on this, probably at the weekend, if not next week.
7 Dec 2007
Swansea, Wales
Ok so currently building (slowly buying bits) for a new water cooled rig.
Want to buy a pair of 980ti's. ... but which ones? I plan to water cool but run on air first to get it built and check everything works (and use them in current rig whilst I but the rest if the bits).
So.....do I buy a reference card eg zontac for sub 500. Which I know has an existing block...or do I splash out 100+ more per card and get a non-ref board for potentially better over clocking but may have to wait for the blocks to come out?
Are we seeing a massive difference between ref and non-ref in oc potential?
Wouldn't mind buying today to have them to play for the weekend ;)
14 Nov 2007
In the Land of Grey and Pink
I believe the Zotac 980 Ti Amp has a reference board.
25 Oct 2007
Los Angeles
Would get reference cards and EK full cover blocks as with that kind of outlay it won't be worth an extra £100 per card for minimal performance gains. Out of interest why do you need two? Assuming it's not for BF4 right?
20 Nov 2005
Redditch
Think I've settled on my 24/7 settings
This was after a 45min run of the render test on GPU-z
Ran Dying Light for about an hour & temps were similar (Maxed at 70c (fan 52%)) & performance was solid.
