** SKYLAKE MEMORY NOW AVAILABLE!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Corsair Dual Channel DDR4 kits are now available from OcUK which are ideal for Skylake, but also remember that current X99 Quad Kits will also work fine in Skylake Z170 mainboards. :)
Corsair Vengeance LPX 8GB (2x4GB) DDR4 PC4-19200C14 2400MHz Dual Channel Kit - Red (CMK8GX4M2A2400C14R) @ £55.99 inc VAT
These Vengeance LPX kits are specifically designed for Intel's latest Skylake platform and of course are compatible with X99 platforms.
Specification:
- CPU Compatibility: Intel Haswell-E & Intel Skylake
- Chipset: Intel X99 / Z170
- Capacity: 8GB (4GBx2)
- Dual Channel kit: Yes
- Tested Speed: DDR4-2400 MHz (PC4-19200)
- Tested Latency: 14-16-16-31
- Tested Voltage: 1.2V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 288-pin UDIMM
- SPD Speed: 2133 MHz
- SPD Voltage: 1.2V
- Warranty: Lifetime
Only £55.99 inc VAT.
ORDER NOW
Corsair Vengeance LPX 8GB (2x4GB) DDR4 PC4-19200C14 2400MHz Dual Channel Kit - Black (CMK8GX4M2A2400C14) @ £55.99 inc VAT
Specification:
- SPD Voltage: 1.2V
ORDER NOW
Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-19200C14 2400MHz Dual Channel Kit - Red (CMK16GX4M2A2400C14R) @ £99.95 inc VAT
Specification:
- Capacity: 16GB (8GBx2)
- SPD Voltage: 1.2V
Only £99.95 inc VAT.
ORDER NOW
Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-19200C14 2400MHz Dual Channel Kit - Black (CMK16GX4M2A2400C14) @ £99.95 inc VAT
Specification:
- SPD Voltage: 1.2V
ORDER NOW
Corsair Vengeance LPX 8GB (2x4GB) DDR4 PC4-21300C16 2666MHz Dual Channel Kit - Black (CMK8GX4M2A2666C16) @ £59.99 inc VAT
Specification:
- Tested Speed: DDR4-2666 MHz (PC4-21300)
- Tested Latency: 16-18-18-35
- SPD Voltage: 1.2V
Only £59.99 inc VAT.
ORDER NOW
Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-21300C16 2666MHz Dual Channel Kit - Black (CMK16GX4M2A2666C16) @ £109.99 inc VAT
Specification:
- SPD Voltage: 1.2V
Only £109.99 inc VAT.
ORDER NOW
Corsair Vengeance LPX 8GB (2x4GB) DDR4 PC4-24000C15 3000MHz Dual Channel Kit - Red (CMK8GX4M2B3000C15R) @ £65.99 inc VAT
Specification:
- Tested Speed: DDR4-3000 MHz (PC4-24000)
- Tested Latency: 15-17-17-35
- SPD Voltage: 1.2V
Only £65.99 inc VAT.
ORDER NOW
Corsair Vengeance LPX 8GB (2x4GB) DDR4 PC4-24000C15 3000MHz Dual Channel Kit - Black (CMK8GX4M2B3000C15) @ £65.99 inc VAT
Specification:
- SPD Voltage: 1.2V
ORDER NOW
Corsair Vengeance LPX 8GB (2x4GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Red (CMK8GX4M2B3200C16R) @ £74.99 inc VAT
Specification:
- Tested Speed: DDR4-3200 MHz (PC4-25600)
- Tested Latency: 16-18-18-36
- SPD Voltage: 1.2V
Only £74.99 inc VAT.
ORDER NOW
We shall be phasing in more kits in coming days/weeks from the likes of Kingston, TeamGroup and Avexir. :)
Awesome, made a post querying where these kits were a few days ago.
Glad to see they are available now :)
Any sign of 16GB Dimms being available soon? As in a 32GB kit (2X16GB)?
they do exist just check out the corsair website ;) i have some in my x99
costly though
though by skylake release will be pushing close to 4000 mhz , speed increases very minimal from top ddr3 and there no 2x8 gig 3000mhz kits :(
Hi there
More models available including whopping 32GB Dual Channel kits and good prices!! :)
Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-24000C15 3000MHz Dual Channel Kit - Black (CMK16GX4M2B3000C15) @ £129.95 inc VAT
Specification:
- SPD Voltage: 1.2V
Only £129.95 inc VAT.
ORDER NOW
Corsair Vengeance LPX 32GB (2x16GB) DDR4 PC4-19200C14 2400MHz Dual Channel Kit - Black (CMK32GX4M2A2400C14) @ £239.99 inc VAT
Specification:
- Capacity: 32GB (16GBx2)
- SPD Voltage: 1.2V
Only £239.99 inc VAT.
ORDER NOW
More to come as well. :)
yes I am mate. Just because of where I'm coming from to be honest mate. I'm on a mATX Z77 and 3770K still, I need new combo to give me more room between the PCI-e slots so my top 390 can breathe a little lol.
Ahh, understand as I had the same issue with sli 780 on the board in sig, despite it being full ATX. Prices for ddr4 are a lot cheaper than I thought they'd be tbh. Now just have to wait for board and cpu prices. Wont be a massive upgrade from a 4790k, but I'm on a pretty much dead end socket now with Z87. Also id like a wider spaced board too incase I go sli again.
A sensible upgrade.
Were doing some testing between Skylake and X99, as we believe we could offer X99 upgrades and systems for near similar money but the X99 in theory has a lot more horsepower, more cores/threads, quad vs dual channel and more PCI-E lanes. If X99 can be had for only a small amount more cash then maybe X99 is the better option with a 5820k. :)
I've considered X99 myself Gibbo, but been put off a bit by the price of boards. But I do suspect that it will be a better investment in the long term. Particularly the 6 cores on the 5820k. Will be interesting to see how it compared to skylake.
Seen those mate, Asus ones look good. And tbh id prefer to stick with them. I'm probably a bit mad tbh for considering an upgrade, not to say my current setup is poor or slow.:o:D
