390 is a lot better than the 290x isn't it?
Most of the 390's have good coolers and are about the same price as the 970 unless you go for the cheaper 970 variants which will have poorer heatsinks like the Zotac and Palit reference for around £240.
Used 970/290x and overclock. The 8gb vram on the 390 is useless. Get a cheaper card, treat it as a stopgap and save money to buy something truly new that can actually benefit from the memory it's been outfitted with.
At the moment, there's nothing better in terms of price/perf ratio than a second hand 970/290x.
A non ref gtx980 2nd hand i would say. Beats both 390/x and ofc the 970.
Are you talking 1440p or 1080p?
970 with its meager 3.5gb is irrelevant when you have the 390 at similar pricing. For 1440p I would be going the 390.
Yep, 970 new are currently overpriced, IMO they should be £200 new.
than a used 970 is just a pipe dream. You don't need more than 4gb vram on such weak cards. 970 is overpriced, end of. Rebrand or not the 390 beats it and has way more memory for demanding games like gta5 and som, 390 is better suited for upcoming games with high memory requirements. More so when you crossfire it.
Let's give your crossfiring argument a whirl maybe? A 980Ti, which performs around 2x390, is not enough for 4k and not because of vram but because of lack of grunt. How's the magical 8gb on the 390 going to help then?
Stop spreading false information. No way is a 980Ti twice the performance of a 390.
Check out the following and you can see that at 4K, the 390 is roughly 2/3rd the performace of a 980ti so the truth is that 2x390 will in fact be 20-30% faster than a 980Ti for basically the same price. Crossfire 390's will be hitting 60fps in games where the 980ti may not.
http://www.guru3d.com/articles_pages/powercolor_radeon_r9_390_pcs_8gb_review,24.html
