I get you! Looks like the root of typical Windows media. Does this mean I can effectively remove it (to media etc) until I'm ready? What about keysits a hidden folder on the root of the C: drive
it will update keeping files and programsIs win10 a fresh install or does it carry some programs over from 8? Seeing conflicting views on the web
i suggest you run the compatibility checker to make sure all programs are ok.Wow okay, brilliant
No hidden folder on the root of C: for me.![]()
Installation Failure: Windows failed to install the following update with error 0x80240020: Upgrade to Windows 10 Home.
After 8.1 > 10 upgrade did a fresh install on a brand new SSD, it did ask for the key twice but skipped it both times, after first boot was all activated.
So yes, you can upgrade your HDD/SSD without issue.
Wonder if the files in this hidden folder are the same for everyone (cant see it being different? Too much work). In which case it will most likely be downloadable from a torrent or something and you will just have to make that hidden folder and run it.
This literally just appeared in Event Viewer...
Any ideas?
I've tried all sorts to get the Windows 10 upgrade icon but still can't manage it!
Could someone look at the MediaMeta.xml file in the hidden folder and check if your
<taskguid>6a920c71-****-****-***c-*****415eb7f</taskguid>
is different?
Time lock, won't install till 00:00 at the earliest depending when Microsoft 'flick the switch'
here is mine
<taskguid>6a920c71-9****-45**-a19c-a****415eb7f</taskguid>
