Not seeing the point in a fresh install on Win 10 tbh. It is based on Win 8.1 so I doubt doing an upgrade will cause any issues. I hope not anyway as I cannot be bothered re-installing everything. I can now guarantee I will be the one with the failed update....![]()
Installed and activated. Very smooth. Took just under 30 minutes.
Is the "wuauclt.exe /updatenow" command supposed to start the download to the $Windows.~BT folder? If that's the case it isn't working here
Its true but I would much rather go for a completely clean install, just in case something goes wrong with drivers etc! Just my own feeling though.
I hope I can do the inbuilt factory reset option rather than need a disk, cba plugging my drive back in tonight
Am I missing something here, do you get a new key with this or whatAnd will said key supersede your Windows 7/8 key?
When you reinstall 10 in the future, it will base your license off your hardware hash, so no key will be required.
When you guys made the ISO, did you select option 1 or 2?Initially I used option 2, but going to try option 1 as my install failed every time.
We have to make an ISO? I have no discs, and the only USB Drive I have is 8GB..
Well I'm all pre-loaded up.
Will I be able to update past midnight?
Nope midnight EST or 05:00 here...
