I just used the wuauclt.exe /updatenow command and it started the update. I already had the files downloaded..
Just adds another fail to the list for me....
Thanks, worked for me. Shows "Preparing for installation".
Hmm. Bit worried about the keep nothing option. I would assume it only relates to the install drive....
It will just be the OS partition.
