- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Has nobody seen the MAJOR flaw with Windows 10 free upgrade??
The upgrade is tied to your hardware, as first install requires an activated Window 7 or 8 with a valid activation key.
Then Windows 10 activates when upgraded and it uses a generic key from there.
The Windows activation then is tied to your hardware and will activate with a new fresh install from then onwards, maybe it ties your license to your BIOS serial numbers or something, as future installs do NOT need any license keys and you do not have the option to put in a key.
So what if you upgrade? Your hardware ID will change. How will that work? Will you need to install 8.1 everytime? and then install 10 over the top of it? And what happens after the first "free year"
If so, that is rubbish.
