- 19 Nov 2011
SNIP]
My upgrade fails what next?
Have you tried downloading the ISO, and verified the HASH?
SNIP]
how long can i wait before doing the windows 10 update? it has never popped up for me and i have registered for it. guna do a proper format and reinstall windows 7 soon.
You have a year for the free upgrade. So no rush![]()
i saw that in the main post. i dotn really want to go that way until i have actually sorted my problems out. made a hash of changing my boot drive so now i have two options when i turn computer on. it will be fixed soon though. if that doesnt work then i will do what that says, thanx anyway
I ran the ISO from inside windows and it installed on one computer.
Can I use the same downloaded ISO for my other computers?
In case anyone is setting up a box, I compiled this list of stuff that annoyed me and how to change it:
Disable Web Search
Start, type random gibberish. Click Cog, turn off Include web search results
Default Browser
Start > Settings. System > Default apps.
Shrink Start Menu
drag edge to make narrower (may need to remove tiles first)
Disable Lock Screen Splash (pointless keystrokes or clicks)
Code:[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\Personalization] "NoLockScreen"=dword:00000001 [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Authentication\LogonUI\TestHooks] "Threshold"=dword:00000000
Remove Search Bar
Right click taskbar, Search > Hidden
Remove Task Switcher
Right click taskbar, Show Task View button
Snap Behaviour
Start > Settings. System > Multitasking disable When I snap a window, show what I can snap next to it
Privacy
Start > Settings. Privacy
General
advertising id (tracking)
how I type (tracking, pw leakage?)
language list (tracking)
Location - turn off
Account Info - turn off sharing
Contacts - turn off
Messaging - turn off
Background apps - turn off
Camera / Microphone - turn off
Enable Hibernate
Control Panel > Power Options > Choose What Buttons Do. Shutdown Settings. (may need to do powercfg -h on)
Would this work ?
Dad has a laptop with windows 7 but some windows updates won't install so the Windows 10 Notification won't install.
If i downloaded Windows 10 Home (as hes using Windows 7 Home Preimum) using the Media creator and burned an ISO would the upgrade work on his PC using the image I've downloaded ?
Would it activate ?
This error seems to be cropping up a lot.
http://forums.overclockers.co.uk/showpost.php?p=28375280&postcount=6655
