Is it possible to download the Windows 10 iso
As I will need to format tomorrow
Yes, look in the Windows 10 FAQ thread.
Everything went smoothly for me - decided to do an upgrade and then a full refresh, just re-installing development tools and battle.net and then will probably re-install Office tomorrow.
I thought the update had gone well but Cortana is missing in action and edge doesn't work. Back to 8.1 for me.
6) Went to the store page and converted my Home to Pro.. took ages for it to finish that simple task
so you payed £99?
@Varkanoid, the only big space saver in disk cleanup for me, is the "previous installation" of 27GB, kinda worried to remove it.. Would it be safe to do so? I know it may seem an odd question.
No.. there was an option to convert the installation to pro. The store seems to be more than just a market place for purchases but also a place to sort upgrades and such to your installation without paying anything(as long as your liable to get it)
I have a netbook with windows 8.1 with bing. would this just be upgraded to W10 Home?
cant see it on the list when it states what you get upgraded too
Got a clean install working and activated on a new SSD.
you had to do the upgrade then activate it then find out the product key (which is new) then use that product key to activate the new install.
