Just looked at that. No way to change it to a network share on my server?
I'm not liking how many of my games/programs aren't working and how much of a shambles the Nvidia graphics drivers appear to be at the moment.
My laptop has also Bluescreened once and before that BSOD was really slow at setting up. I guess I may have to try a fresh install at some point, on my main PC anyway, it's just that I'm confused over which key I should use. My Windows 8.1 Key or the Windows 7 key before it? A reinstall on my laptop is easy as I only have a Windows 7 key...
Have you tried spamming the activation button?![]()
You no longer need a key once windows 10 has activated.
Just skip the input key step on a fresh install and it will activate once windows goes online. Its tied to your PC's hardware ID now.
I think servers are overloaded for activation,mine upgraded fine but can't activate says "try later ",no error code and no watermark since it's a upgrade from 8.1.
Anyone else unable to activate after upgrade, dispute having previously activated genuine win 8.1 before?
Yes, same here. Upgraded from Win 8.1 and activated fine.
Did a clean install, left the key blank and now unable to activate. This time, the activate button disappears after the first activation failure. Perhaps a feature of their new activation process maybe?
Did a restore back to a Win 8.1 system image and just doing an upgrade of Win 10 over it now. Other articles seem to suggest that its all related to busy servers but seems odd that there's no longer an activate button anymore and The 0xC error codes seem a bit misleading...
I'm just going to right click on the folders and change location the old way.
My laptop keeps hanging on boot during installation, reporting error code 0xc1900101 0x20017 and something about failing at SAFE_OS phase.
Any ideas?
I'm currently having the same thing on ky fresh install. Its saying the key is blocked.
