** NICE NICE PRICES ON SOLID STATE STORAGE!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Got some very NICE prices on SSD's:
Kingston 60GB SSDNow V300 Drive SATA 6Gb/s 3 2.5" (7mm height) Solid State Hard Drive - (SV300S37A/60G) @ £32.99 inc VAT
Kingston's SSDNow V300 solid-state drive is a cost-efficient performance upgrade that revives your personal computer and makes it more responsive. It's 10 times faster than a 7200RPM hard drive plus more reliable, more durable and shock-proof, with no moving mechanical parts. It features an LSI® SandForce® controller customised for Kingston and best-in-class components that are affordable for first-time SSD owners. SSDNow V300 is available in kits with all the accessories needed for an effortless transition to the latest technology for less than the cost of a new system. For added peace of mind, it's backed by a three-year warranty, free technical support and legendary Kingston® reliability.
Features:-
- Improves speed of loading applications and system boot up
- No moving parts, solid-state drives are less likely to fail than standard hard drives
- Design optimised to make migrating to an SSD more a ordable
- All-in-one kits with all the components for easy installation
- Multiple capacities to fit your workload
- 2.5-inch drive available in 7.0mm with adapter to fit in 9.5mm systems
- Cool and silent operation
Specification:-
- Form factor: 2.5" SATA
- Capacity: 60GB
- Controller: SandForce SF-2281
- Maximum Read: 450MB/sec
- Maximum Write: 450MB/sec
- Random 4k read/write: 85,000/60,000 IOPS
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- Warranty: 3 Years
Was [£35.99] Inc. VAT
Only £32.99 inc VAT.
ORDER NOW
Crucial BX100 120GB SSD SATA 6Gbps 7mm Solid State Drive (CT120BX100SSD1) @ £44.99 inc VAT
nonl2br
<p>Boot up almost instantly. Load programs in seconds. And accelerate demanding applications with ease. It all starts with ditching your hard drive.</p>
<p>The storage revolution that started in 2008 with our first SSD continues with the new Crucial® BX100. Engineered to outperform a hard drive and deliver cost-effective performance, the Crucial BX100 leverages advanced flash memory technology and moves your computer beyond the outdated storage limitations of spinning discs. By transmitting data in a digital manner rather than having to seek it out on a spinning platter, the Crucial BX100 makes nearly everything on your computer faster and more efficient.</p>
<b>Over 15x faster than a typical hard drive</b>
<p>Get more done in less time – or just have more fun. The Crucial BX100 SSD is over 15 times faster than a typical hard drive and delivers true 535 MB/s sequential reads on both compressible and incompressible data. By treating all data the same, the Crucial BX100 allows you to do everything quickly, regardless of whether you’re saving an image, accessing a ZIP file, or loading a video.</p>
<b>Over 2x more reliable than a typical hard drive</b>
<p>Protect your data by storing it on the Crucial BX100, which is significantly more reliable than a typical hard drive. In the computer industry, storage drive reliability is measured in mean times between failures (MTBF). Most hard drives have MTBF ratings of 0.6 million hours, whereas the Crucial BX100 has a reliability rating of 1.5 million hours. In practical terms, the more reliable your drive is, the less likely it is to crash.</p>
<b>Nearly 2x more energy efficient than a typical hard drive</b>
<p>Run your system longer and harder – using less power. With Extreme Energy Efficiency technology, the Crucial BX100 is over 90% more energy efficient than a typical hard drive. Since SSDs access data digitally rather than seeking it out on a spinning platter, they consume significantly less power.</p>
<b>Better value than a typical SSD</b>
<p>Get more out of your system – without compromising quality. At speeds up to 535 MB/s, the Crucial BX100 SSD isn’t the fastest drive on the market, but that’s squarely our intent. We painstakingly engineered the Crucial BX100 to provide a massive performance boost, while also delivering an unrivaled value among SSDs. Make the switch to the Crucial BX100 and get everything you expect from a Crucial SSD at an unexpected value.</p>
<b>Specifications:</b>
<ul>
<li>Sequential Read MB/s: 535
<li>Sequential Write MB/s: 185
<li>Random Read IOPS: 87k
<li>Random Write IOPS: 43k
</ul>
Was [£49.99] Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
Kingston 120GB SSDNow V300 Drive SATA 6Gb/s 3 2.5" (7mm height) Solid State Hard Drive - (SV300S37A/120G) @ £39.95 inc VAT
Features:-
Specification:-
- Capacity: 120GB
- Random 4k read/write: 85,000/55,000 IOPS
- Warranty: 3 Years
Was [£44.99] Inc. VAT
Only £39.95 inc VAT.
ORDER NOW
Kingston HyperX 3K SSD 120GB 2.5" SATA 6Gb/s Solid State Drive (SH103S3/120G) @ £59.99 inc VAT
The all new Kingston HyperX 3K SSD featuring the Sandforce SF-2281 controller for blistering fast reads and writes and industry leading IOPS.
- 95k IOPS
- Capacity: 120GB
- Maximum Read: 555MB/sec
- Maximum Write: 510MB/sec
- Max I/O Per Second (IOPS): 95000 IOPS (4KB File, READ)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Included in the box
- SSD 2.5" to 3.5" adaptor in metalic blue
- Mounting screws
Was [£65.99] Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Kingston HyperX Fury 120GB 2.5" SATA 6Gbps Solid State Drive (SHFS37A/120G) @ £41.99 inc VAT
nonl2br
<h3>High performance. Low price. You game? </h3>
<p>HyperX® FURY solid-state drive delivers impressive performance at an affordable price, to get you into the game faster and improve your gameplay. It features a slim 7mm form factor and SandForce® SF-2281 controller with SATA Rev 3.0 (6Gb/s) performance for faster system boot up, application loading and file execution plus faster map and level load time. Its synchronous NAND allows for higher and consistent drive performance. So you're not only in the game, you're winning it.</p>
<p>HyperX FURY SSD is available as a stand-alone drive and is easy to install. This cost-e cient upgrade is less disruptive than buying a new system to increase performance. The new FURY entry-level product line from HyperX includes memory and SSDs and is designed for gamers, enthusiasts and system Integrators, who can now have consistent HyperX branding for their gaming PCs. </p>
<p>Built with Flash memory, HyperX FURY SSD has no moving parts and is cooler, quieter and more shock- and vibration-resistant than traditional hard drives, making it the ideal hard drive replacement. It’s backed by a three-year warranty and free technical support.</p>
<ul>
<li>SandForce controller with SATA Rev 3.0 (6Gb/s) performance
<li>Read/write speeds of 500/500 MB/s
<li>Features synchronous NAND for consistent high SSD performance
<li>Faster system boot up times, application loading & file execution
<li>Faster map and level load times in game with increased frames per second
</ul>
<p>Baseline performance Compressible data transfer (ATTO) All capacities: 500MB/s read and 500MB/s write. Incompressible data transfer (AS-SSD and CrystalDiskMark)
<ul>
<li>120GB — 420MB/s read and 120MB/s write
</ul>
<b>Maximum 4k Read/Write</b>
<ul>
<li>120GB — up to 84,500/ up to 52,000 IOPS
</ul>
<b>Random 4k Read/Write
<ul>
<li>120GB — up to 11,500/ up to 52,000 IOPS
</ul>
<b>PCMark® Vantage HDD Suite Score</b>
<ul>
<li>120GB — 60,000
</ul>
<b>PCMark 8 storage bandwidth</b>
<ul>
<li>120GB – 140 MB/s
</ul>
Only £41.99 inc VAT.
ORDER NOW
Samsung 120GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E120B/EU @ £49.99 inc VAT
nonl2br
<b>Specifications</b>
<ul>
<li>Controller: Samsung MGX Controller
<li>DRAM Cache Memory: 256MB
<li>Sequential Read: 540Mbps
<li>Sequential Write: 520Mbps
<li>4KB Random Read (QD1): Max 10,000 IOPS
<li>4KB Random Write (QD1): Max 40,000 IOPS
<li>4KB Random Read (QD32): Max 94,000 IOPS
<li>4KB Random Read (QD32): Max 88,000 IOPS
<li>Reliability: MTBF: 1.5 million hours
<li>Warranty: 5 Years
<li>TBW: 75TBW
<li>Data Security: AES 256-bit Full Disk Encryption (FDE) / TCG/Opal V2.0 Encrypted Drive (IEEE1667)
</ul>
<b>3D V-NAND Technology and THE SAMSUNG SSD 850 EVO</b>
<p>Samsung’s unique and innovative 3D V-NAND flash memory architecture is a breakthrough in
overcoming the density limitations, performance and endurance of today’s conventional planar NAND architecture. 3D VNAND is fabricated by stacking 32 cell layers vertically over one another rather than
decreasing the cells dimensions and trying to fit itself onto a fixed horizontal space resulting in
higher density and better performance utilizing a smaller footprint.</p>
<p>The 850 EVO is the advanced consumer SSD powered by 3D V-NAND technology that maximizes everyday computing experiences with optimized performance and enhanced reliability.</p>
<b>Optimized performance for everyday computing experiences</b>
<p>Powered by Samsung's cutting-edge 3D V-NAND technology, 850 EVO delivers top-class sequential
and random read and write performance to optimize everyday computing. With improved performance thanks to TurboWrite technology the 850 EVO provides not only more than a 10% better user experience than 840 EVO but up to 1.9x faster random write speeds for the 120/250 GB models as well. In fact, the 850 EVO delivers top class sequential read (540 MB/s) and write (520 MB/s) performance in all capacities. This comes with optimized random read and write performance on all QD and improved QD1 and QD2 random performance for Client PC usage.</p>
<b>Reinforcement of TurboWrite Technology</b>
<p>In the early stages of the 840 EVO, Samsung adopted sequential write performance first. With
TurboWrite, write speeds are significantly accelerated during data transfers by creating a high-performance write buffer in the SSD. If a consecutive write operation (i.e. no idle time) exceeds the size of the buffer, the transfer will exit TurboWrite and be processed at ”After TurboWrite” speeds. Once the buffer is cleared, TurboWrite performance will resume. However, the buffer size for TurboWrite is more than sufficient for everyday PC use, and you should experience accelerated speeds for most workloads. </p>
<p>For the 850 EVO, enhanced TurboWrite technology applied to random write speeds up to 1.9x faster for the 120 GB model and 1.25x faster for the 250GB model over the 840 EVO.</p>
<b>Guaranteed endurance and reliability for maximum use</b>
<b>Guaranteed endurance</b>
<p>The 850 EVO delivers guaranteed endurance and reliability by doubling the TBW compared to the
previous generation 840 EVO backed by an industry leading 5 year warranty. With twice the endurance of a typical NAND flash SSD, the 850 EVO will keep working as long as you do. The 850 EVO guarantees a 5 year limited warranty or 75TBW for 120GB and 250GB, 150TBW for 500GB and 1TB.</p>
<b>Enhanced reliability with improved sustained performance</b>
<p>With enhanced reliability through improved sustained performance, the 850 EVO assures longterm
dependable performance up to 30% longer than the 840 EVO with minimized performance degradation. This means you can use it every day when taking care of work or entertaining yourself knowing it will keep performing even with heavy daily workloads over the years.</p>
<b>Advanced data encryption</b>
<p>The 850 EVO provides the same data encryption feature as the 840 EVO does. Self-Encrypting Drive
(SED) security technology will help keep data safe at all times. It includes an AES 256-bit hardwarebased
encryption engine to ensure that your personal files remain secure. Being hardwarebased, the encryption engine secures your data without performance degradation that you may experience with a software-based encryption. Also, 850 EVO is compliant with advanced security management solutions (TCG Opal and IEEE 1667). Magician will guide ”How to use security features”. Furthermore, you can erase or initialize data with the crypto erase service with PSID.</p>
<b>Efficient power management for all PC applications</b>
<p>Power consumption affects everyone. You actually save of up to 50% more on power than
with the 840 EVO during write operations thanks to 3D V-NAND consuming half the power of 2D
planar NAND. </p>
<p>Plus, whether it’s preserving battery life for longer cordless use or just saving on costs, power
management is important. Device sleep signals the SSD to enter a low power state which is vital for
ultra-books and other battery powered devices. With 850 EVO’s Device Sleep at a highly efficient
2mW you get longer battery life on your notebook thanks to a controller optimized for 3D V-NAND.
With the 850 EVO you can work and play longer without having to plug in.</p>
<b>Summary</b>
<ul>
<li>SATA 6Gb/s SSD for Client PCs
<li>2.5 inch form factor
<li>Samsung 32 layer 3D V-NAND
<li>Samsung Magician Software for SSD management
<li>Samsung Data Migration Software
</ul>
Was [£59.99] Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
Crucial BX100 250GB SSD SATA 6Gbps 7mm Solid State Drive (CT250BX100SSD1) @ £65.99 inc VAT
nonl2br
<ul>
<li>Sequential Write MB/s: 370
<li>Random Write IOPS: 70k
</ul>
Was [£68.99] Inc. VAT
Only £65.99 inc VAT.
ORDER NOW
Crucial BX100 500GB SSD SATA 6Gbps 7mm Solid State Drive (CT500BX100SSD1) @ £129.95 inc VAT
nonl2br
<ul>
<li>Sequential Write MB/s: 450
<li>Random Read IOPS: 90k
</ul>
Was [£139.99] Inc. VAT
Only £129.95 inc VAT.
ORDER NOW
Kingston 240GB SSDNow V300 Drive SATA 6Gb/s 3 2.5" (7mm height) Solid State Hard Drive - (SV300S37A/240G) @ £65.99 inc VAT
Features:-
Specification:-
- Capacity: 240GB
- Random 4k read/write: 85,000/43,000 IOPS
- Warranty: 3 Years
Was [£71.99] Inc. VAT
ORDER NOW
Kingston 480GB SSDNow V300 Drive SATA 6Gb/s 3 2.5" (7mm height) Solid State Hard Drive - (SV300S37A/480G) @ £137.99 inc VAT
nonl2br
<p>Get more life out of your computer and maximise your existing investment by replacing your old hard drive with a Kingston® SSDNow V300 solid-state drive. It’s the most cost-e cient way to dramatically improve the responsiveness of your system —*and it’s less disruptive than migrating your data to a new system.</p>
<p>SSDNow V300 features an LSI® SandForce® controller customised for Kingston and optimised for next-generation Flash memory to deliver the utmost in quality and reliability from two leading SSD brands. Because it’s made with solid-state components and has no moving parts, it’s shock-proof and withstands drops and bumps.</p>
<p>SSDNow V300 is easy to install and available in kits that include all the accessories you’ll need, including the software to clone your  les and OS in minutes. It’s backed by a three-year warranty, free technical support and legendary Kingston reliability.</p>
<b>Features:</b>
<ul>
<li>Faster — improves speed of loading applications and system boot up
<li>Reliable — with no moving parts, solid-state drives are less likely to fail than standard hard drives
<li>Economical — design optimised to make migrating to an SSD more a ordable
<li>Convenient — all-in-one kits with all the components for easy installation
<li>Multiple capacities — to  t your workload
<li>Form factor — 2.5-inch drive available in 7.0mm with adapter to fit in 9.5mm systems
<li>Silent — cool and silent operation
</ul>
<ul>
<li>Form factor 2.5"
<li>Interface SATA Rev. 3.0 (6Gb/s) – with backwards compatibility to SATA Rev. 2.0
Capacitie: 480GB
<li>Baseline performance Compressible data transfer (ATTO): 450MB/s read and 450MB/s write
<li>Incompressible data transfer (AS-SSD and CrystalDiskMark): 480GB - 450MB/s read and 208MB/s write
<li>IOMETER maximum random 4k read/write: 480GB — up to 73,000/ up to 28,000 IOPS
<li>PCMARK® Vantage HDD Suite score: 480GB: 57,000
<li>Power consumption: 0.640 W idle / 1.423 W read / 2.052 W write
<li>Storage temperatures -40°C~85°C
<li>Operating temperatures 0°C~70°C
<li>Dimensions 69.8mm x 100.1mm x 7mm
<li>Weight 58.45g
<li>Vibration operating 2.17G peak (7–800Hz)
<li>Vibration non-operating 20G peak (10–2000Hz)
<li>Life expectancy 1 million hours MTBF
<li>Warranty/support 3-year warranty with free technical support
<li>Total Bytes Written (TBW): 480GB: 256TB
</ul>
Was [£149.99] Inc. VAT
Only £137.99 inc VAT.
ORDER NOW
Samsung 250GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E250B/EU) @ £77.99 inc VAT
nonl2br
<ul>
<li>DRAM Cache Memory: 512MB
<li>4KB Random Read (QD32): Max 97,000 IOPS
<li>TBW: 75TBW
</ul>
planar NAND. </p>
<b>Summary</b>
<ul>
</ul>
Was [£89.99] Inc. VAT
Only £77.99 inc VAT.
ORDER NOW
Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E500B/EU) @ £139.99 inc VAT
nonl2br
<ul>
<li>4KB Random Read (QD32): Max 98,000 IOPS
<li>4KB Random Read (QD32): Max 90,000 IOPS
<li>TBW: 150TBW
</ul>
planar NAND. </p>
<b>Summary</b>
<ul>
</ul>
Only £139.99 inc VAT.
ORDER NOW
Crucial BX100 1.0TB SSD SATA 6Gbps 7mm Solid State Drive (CT1000BX100SSD1) @ £259.99 inc VAT
nonl2br
<ul>
</ul>
Was [£289.99] Inc. VAT
Only £259.99 inc VAT.
ORDER NOW
Samsung 1.0TB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E1T0B/EU) @ £281.99 inc VAT
nonl2br
<ul>
<li>Controller: Samsung MEX Controller
<li>DRAM Cache Memory: 1GB
<li>TBW: 150TBW
</ul>
planar NAND. </p>
<b>Summary</b>
<ul>
</ul>
Was [£299.99] Inc. VAT
Only £281.99 inc VAT.
ORDER NOW
Samsung 1TB SSD 850 PRO SATA 6Gbps 3D NAND Solid State Drive (MZ-7KE1T0BW) @ £359.99 inc VAT
nonl2br
<p>The Samsung SSD 850 PRO delivers blazing-fast speeds with an exceptionally high endurance and provides the highest performance of SSDs with SATA III (6Gb / s) interface. The sequential read performance is achieved up to 550 megabytes per second (MB / s), the Write performance up to 520 MB / s The random read performance of up to 100,000 Input/Output- Operations per second (IOPS), the write speeds up to 90,000 IOPS.</p>
<h3>The World's First 3D V-NAND SSD One giant leap ahead</h3>
<ul>
<li>NAND: Samsung V-NAND 32 Layer
<li>Form Factor: 2.5" 7mm
<li>Sequential Read: 550 MB/s
<li>Sequential Write: 520MB/s
<li>Random 4KB IOPS Read (QD=1): 10,000
<li>Random 4KB IOPS Write (QD=1): 36,000
<li>Random 4KB IOPS Read (QD=32): 100,000
<li>Random 4KB IOPS Write (QD=32): 90,000
<li>DevSlp Power: 2.0mW
<li>Warranty: 10 Years / 150 TBW
</ul>
<b>What is V-NAND and how does it differ from existing technology?</b>
<p><iframe width="560" height="315" src="//www.youtube.com/embed/aSet77w_SCk?list=UU-Zmz57JJyk99uUO0l27U5Q" frameborder="0" allowfullscreen></iframe></p>
<p>Samsung's 3D V-NAND flash memory is fabricated using an innovative vertical design. Its vertical architecture stacks 32 cell layers on top of one another rather than trying to decrease the cells' length and width to fit today's ever-shrinking form factors. This architecture results in higher density and higher performance using a smaller footprint. Samsung's 3D V-NAND technology is a breakthrough in overcoming the density limits currently faced with conventional planar NAND architecture.</p>
<b>Boost performance with an industry-leading 3D V-NAND SSD</b>
<p>Powered by Samsung's own cutting-edge 3D V-NAND technology, the 850 PRO delivers up to two times the density and write speed when compared with traditional 20 nm planar NAND flash for the ultimate in read and write performance. By changing to a 32-layer cylindrical cell structure, more cells can be stacked vertically, resulting in a smaller footprint and higher density. As a result, you gain superior maximum read and write performance in both sequential and random aspects, especially the 128GB model that outperforms other similar models in the market by more than 100Mb/s in write speed.</p>
<b>Shift into high gear with the RAPID mode</b>
<p>Plus, you can kick up the read/write performance on every capacity when you need it with the RAPID mode. Just like shifting gears in a car, Magician software gives you the option to enhance performance by processing data on a system level using free PC memory (DRAM) as a cache. The 128 GB model, for example, is able to double its performance by using the V-NAND technology.</p>
<b>An SSD that won't quit before you do</b>
<p>With twice the endurance and reliability of a typical NAND flash SSD, the 850 PRO will keep working as long as you do. Samsung's V-NAND technology is built to handle an 80 GB daily workload, which equates to 150 Terabytes Written (TBW), enabling you to use the SSD for long periods of time. Plus, it comes with the industry's top-level ten-year limited warranty.</p>
<b>Work longer with high-efficiency innovation</b>
<p>The efficient, power management components in the 850 PRO enable you work longer and more productively. The 850 PRO boasts the lowest power consumption of any SSD when in full use so that power consumption is minimized while market-leading performance is maintained., And, in the device sleep mode, it consumes only 2 m watts of power, as determined in test results on an Ultrabook™ device. Plus, its LPDDR2 cache memory provides higher performance while consuming 30 percent less power when active and 93 percent less power when idle than typical DDR2 or DDR3 memory.</p>
<b>Safeguard precious data without sacrificing performance</b>
<p>When you take your laptop on the road, you not only need to protect your PCs hardware, but your personal data, too. But don't worry. The 850 PRO's Self-Encrypting Drive (SED) technology will help keep it safe, even if you lose your laptop. The drive includes an AES-256-bit hardware-based, full disk encryption engine that secures your data without performance degradation, which is often experienced with software-based encryption.</p>
<p>The 850 PRO's advanced security complies with the Trusted Computing Group™ (TCG) Opal v2.0 standards, protecting Postscript Image Data (PSID), and is compatible with the Microsoft? eDrive Institute of Electrical and Electronics Engineers (IEEE) 1667 protocol. Plus, you can erase or initialize data with the crypto erase service.</p>
<b>Protect your PC from overheating with Dynamic Thermal Guard protection</b>
<p>To ensure it won't let you down, the 850 PRO includes Dynamic Thermal Guard protection, which keeps your PC performance safe from heat. After all, when you're totally immersed in your work or in a competitive video game, the last thing you want to have happen is for your computer to overheat. Dynamic Thermal Guard protection monitors and maintains the drive's optimal operating temperature with a throttle feature that automatically drops the SSD's temperature when necessary to protect your data and ensure the responsiveness you expect. So, your PC will stay cool, even if you overwork it - and you'll keep your cool, too.</p>
<b>Level up to the 850 PRO simply without any hassle</b>
<p>Samsung has made upgrading to the 850 PRO simple using its One-stop Install Navigator software. You can migrate all the data from your SSD or HDD to the 850 PRO quickly and easily. The Auto Install guide, included in the toolkit, guides you through the simple three-step installation process.</p>
<p>What's more, you can conveniently monitor, manage and maintain your new 850 PRO with the Samsung Magician software that's also available through the One-stop Install Navigator toolkit. The Magician features tools to help you maximize performance, including benchmarking, advanced OS optimization, disk health status tracking and over-provisioning (OP) settings.</p>
<b>Ensure each component works together seamlessly</b>
<p>Samsung is one of the few manufacturers that actually design all the SSD components in-house. And among those who do, Samsung has the most experience in the SSD market. Because Samsung has intimate knowledge of every component and its parts, it can fine-tune them at each stage of development to ensure they work perfectly together. The result – enhanced performance with a 32-layer 3D V-NAND flash memory, lower power consumption with an up to 1 GB LPDDR2 DRAM cache memory and improved energy-efficiency with the 3-core MEX controller.</p>
Was [£379.99] Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
Samsung SM951 256GB M.2 PCI-e Gen3 8Gbps x 4 Solid State Drive (MZHPV256HDGL-00000) @ £131.99 inc VAT
nonl2br
<p>The SM951 boasts outstanding performance, supporting both PCIe 3.0 and PCIe 2.0 interfaces. They can read and write sequentially at 1,600 MB/s (megabytes per second) and 1,350 MB/s respectively based on PCIe 2.0. This performance level is approximately three times faster than that of the latest SSD with a SATA interface and about 30 percent faster than that of the Samsung XP941, its predecessor. In addition, the new SSD's random read and write speeds reach up to 130,000 and 85,000 IOPS (inputs / outputs per second) respectively.</p>
<p>For ultra-slim notebooks and workstations wanting to adopt the PCIe 3.0 interface, the SM951 can read and write sequentially at 2,150 MB/s and 1,550 MB/s respectively, which would provide approximately four times faster sequential reading performance compared to current SATA SSDs. With a PCIe 3.0 interface, the drive achieves substantially higher energy efficiency, requiring only about 450 MB/s per watt for sequential reading and 250 MB/s per watt for sequential writing, which translates into a more than 50 percent improvement in performance per watt over that of the XP941 SSD.</p>
<p>In addition, the SM951 is the first SSD to adopt the L1.2 low power standby mode (which allows all high-speed circuits to be turned off when a PC is sleeping or in hibernation) as defined by PCI-SIG (the PCIe standards body). By embracing the L1.2 level of standby operation, the SM951's power consumption is drastically reduced – to under 2mW, about a 97 percent decrease from the 50mW consumed using a L1 state.</p>
<p>Samsung's SM951 comes in the M.2 form factor (80 mm x 22 mm), which is only about one seventh the size of a 2.5" SSD. Also, it weighs approximately six grammes. The drive's compactness is well suited for most notebook PC designs, freeing up space for other components including the battery. The SM951 lineup consists of 512, 256 and 128 GB SSDs.</p>
<p><b>PLease Note.</b> Some M.2 motherboards only support SATA 6Gbps speeds or PCI-e x 2 lanes. You need to make sure your board supports PCI-E x4 Lanes to get the full speed from this SSD.</p>
<br>
<br>
<b>Specification</b><br>
- M.2 PCI-E 3.0 (x4) interface or M.2 PCI-E motherboard slot<br>
- MLC NAND<br>
- Read Speed: 2150MB/s<br>
- Write Speed: 1200MB/s<br>
- IOPS: 140k/80k<br>
- Warranty: 2yr<br>
Only £131.99 inc VAT.
ORDER NOW
Samsung SM951 512GB M.2 PCI-e Gen3 8Gbps x 4 Solid State Drive (MZHPV512HDGL-00000) @ £239.99 inc VAT
nonl2br
<br>
<br>
- MLC NAND<br>
- Write Speed: 1500MB/s<br>
- IOPS: 140k/85k<br>
- Warranty: 2yr<br>
Was [£259.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
There is now no excuse to not try an SSD with 120GB models starting from under £40, very affordable! :)
Very nice, typically I just bought the 250GB 850 EVO elsewhere for a little more than the reduced price.
Shame the V300s are so awful since the bait and shift, performance has been absolutely crippled compared to the original stats/reviews.
Disappointing prices on the lager/better drives tbh, the sammy 1tb is £30 cheaper elsewhere, the m.2 sammy drives are around a tenner cheaper elsewhere... and the rest of the prices just about bring you in line with other retailers.
I'm only whinging as I'm after a 500gb drive myself :P
deffo need to go back and check your coding also.. missing html everywhere :P
makes the post messy ^_^
shame i already have 5x SSD's i dont think i need more atm lol
It is the forums, we do not care. Website looks fine which is what matters as that is our shop, the forums is not. :)
With the risk of getting another forum penalty point the Sammy SM951 256gb is way too overpriced if you shop around.
So no no no nice nice nice price I am afraid.
What's the best 120 drive for reliability?
Not relevant (or might be) but I'd never dream of getting a 120GB drive, considering my 250GB is nearly full :p This is of course with a few games and various software.
120GB is fine however if you'll just be browsing the net etc
Return rates are as follows:
Crucial: 0.72%
Kingston: 0.93%
Samsung: 0.49%
All very low!
Samsung it is then, though I have always been a fan of Crucial SSD's.
Poppycock. :p
I'm running Win 8.1 and drivers and basic programs on a 64GB Crucial M4! 15GB spare.
2x 1TB, for storage and another for games and another 120GB SSD, which I move games on and off if I regularly play them to cut loading times.
I don't like all my eggs in one basket. :D
Now there is real customer service. Try getting that information out of the rainforest, purple shirters or other online retailers.
That is because we are quite open and happy to share certain data and be rather open and un-opinionated on hardware. :)
The Samsung drives are easily pretty much the best, probably only bettered by Intel for reliability but Intel consumer drives are not so great performance wise or are simply over-priced for the performance.
Poppycock. :p
Oh I have multiple HDDs as well, it's nothing like that at all ;) For the OS drive I prefer keeping things clean but that's not always possible with small SSDs :( Hey at least the prices are coming down :p
almost jumped on the one of the 250gb Samsung Evo's & a 1TB external hdd until I saw DPD adding almost a tenner onto the price for shipping to Northern Ireland.
shame OcUK can't offering more cost effective methods of shipping to NI
OcUK are the best with graphics cards but with storage always seem to fall behind, I got my BX100 cheaper than that over 2 months ago elsewhere with a forest site. Direct from them aswell.
Have to agree with that ^
Looking to get the sm951 but a quick Google shows that it's cheaper at 3 of your competitors? Come on Gibbo! Windows 10 is out, a lot of people (me)may be looking to do fresh installs, give us a good price here!
Two Evo 500s ordered yesterday (with a probable 32 more needed). It's just a shame your warehouse didn't bother to ship them......
