Permabanned
- 1 Jun 2004
- London
Oh damn that must be dirty and slow?
I'm from 2012 and it runs as fast today as it did then.
Well, on Win 10 now guys!! All went smooth as cream! Fingers crossed it stays that way! Now, best way to clean install? mmmm?? Reset maybe?
I've tried the fix in CMD, all updates are installed that are required, and still no Get Windows 10 icon?
Still no luck, even using the ISO from the Windows 10 FAQ thread. Every time it hangs on the blue windows logo after the first restart. Any ideas?
Easy.
Nuke the hard drive from setup USB stick and start over.
New GPU-Z 8.5 is out which works with Windows 10 including Cuda Detect fix
http://www.techpowerup.com/downloads/2524/techpowerup-gpu-z-v0-8-5/
Just go to the Windows FAQ page and download the iso that matches what you should get and run it that way. You dont need to do the icon thing.
How long have you waited on the Blue windows logo for? Is their any sign of hdd activity or anything?
and this will allow me to update from W8.1 as per usual?
Nope still doesnt do it
See:
My windows 10 upgrade nightmare is still continuing since I found that the first attempt failed with a C1900208 error code, and the two attempts that were made yesterday failed with the 80240020 error code and since the folder containing the upgrade files is under 4GB in size it looks like the download was incomplete and I have to do a but of purging and using a bit of BF+I to get it to start downloading everything again.
Also it seems that M$ have removed directX 9 support from windows 10 which would explain the incompatibility report for the 6600LE on my fathers computer.
