GTAV performance thread.
Caporegime
8 Jul 2003
In a house
Awesome running :D
56fps+
61fps+
58fps+
Caporegime
12 Jul 2007
United Kingdom
Matt are you having any issues in regards to fps drops and stutter? i'm getting loads of issues.
Seems to be on the game side rather than AMD Drivers though.
Yes I do mate, but it's a bit better since the patch came out. Free sync really helps mask any stutters, it's wonderful. You still feels big stutters though. I'd say for me it's very smooth 98% of The time.
26 Sep 2013
West End, Southampton
who needs FuryX or watercooling to keep temps silly cool, 390 crossfire making mince meat of GTA V at 1440p with all settings maxed out (apart from grass) whilst keeping pretty damn cool for me, all be it a big difference between top and bottom but thats down to my motherboard PCIe spacing. Playing this on Freesync is indeed massively impressive Matt.
Caporegime
12 Jul 2007
United Kingdom
Yes it does Tony. :)
GTA V looks lovely at 4K. :)
2x Fury X Stock
4K Ultra Settings
FreeSync enabled 59FPS locked
Does anyone else prefer the look of sharp shadows to everything else? I think they look better, perhaps less realistic, than all the other Rockstar options.
That looks lovely matt , any daytime shots ? :cool:
Out in the country side with Ultra grass settings. :)
2x Fury X Stock
4K Ultra Settings
Caporegime
12 Jul 2007
United Kingdom
Awesome temps and quiet as a mouse ;)
I use overdrive to manage my fan speeds and set the target temp for 57C for two gpu's and 52C for four gpu's. Results in lower fan speeds overall i find, but sometimes you get 10-15 seconds of core clock fluctuations whilst powertune does the maths and calculates the bare minimum fan speed needed to maintain the target temperature at the clocks set, depending on the current gpu usage load.
When you have four gpu's working the load is reduced which can actually mean you need less fan speed than if you have less gpu's present. :)
Caporegime
4 Jun 2009
:eek:
That is pretty bad loadsofmoney!
My MSI GE 290 in GTA 5
- average temp is about 66 with an average fan speed of 45%
- max temp is 73 with a max fan speed of 50%
Now that is with the core voltage set to -37 but still even at the default (which for me is +25) it shouldn't be hitting as high as what you are seeeing....
I haven't touched my fan profile stuff.
Caporegime
8 Jul 2003
In a house
:eek:
Yeah its crazy, temps have gone up a couple of degrees, as ive gone from 1080p to 1440p, so must be working harder. :D
Its oc'd to 1080 on the core as well.
Can't wait to get my FX, see those 50 temps :p
6 Aug 2009
Wales
I'll have a little play with it then, like i said it's still quiet even using AB, need to fix this MSAA issue in GTAV, loads of artifacts but it's very random.
Caporegime
4 Jun 2009
Still I don't think you should be hitting that high especially with that fan speed, my case is pretty crap for airflow too (antec p100)
Caporegime
8 Jul 2003
In a house
Might need a bit of a clean tbh, as not been done for a while, got a Phantom 820, so airflows not a prob, got 200mm front blowing in, 200mm top blowing out, 140mm rear blowing out, 140mm bottom blowing up.
6 Jan 2013
Yorkshire
Yup, i found its much more power efficient to run multiple GPUs, 2 graphics cards on 500mhz give about hte same fps as one card on 1200 mhz, but they use a lot less power. Its worked on my 7950s and 290xs so im guessing its hte same for all multi card setups.
18 Sep 2007
London, England
Win10 Nvidia 352.63 SLI
Just upgraded to Win10 and my smooth 60fps GTAV has become unplayable with SLI. Runs at 60fps, then stutters and hits very bad fps for a while. I've had to disable SLI and drop the quality down :( :(
Any workarounds for Win10 SLI?
11 May 2014
Edinburgh
Which drivers?
I am on w10 and actually managed to increase settings on sli!
