The GTX 980 Ti owners thread.
11 Jun 2015
I've just gotten home from travelling after purchasing my AMP! Extreme almost 20 days ago. Chucked it in my case, ASIC quality of 79.9% which is awesome. The card is huge, but has the most sturdy housing of any card I have ever owned. Looks much better in person than in the photos. No push the limit backplate but i find that cheesy anyway. Time to spend hours and hours catching up on my gaming withdrawal. :D
EDIT: This card also fits in my NZXT S340 with NO issues so I'm very pleased!
17 Mar 2009
UK
Can you post a bigger pic, cant make it out :D.
lol, glad I didn't check this on my phone or tablet. The whole forum would shrink into a nothing and being able to click on the spoiler again would be like winning the lottery :p
Looks like those quality MSI 980TI Gaming's are doing very well thanks to availability and price :)
24 Aug 2013
Lincolnshire
One for the Gallery :D. Ignore the damn wallpaper lol. Had to mod my desk as i originally had it at the side and move it into the spare room hense the horrific wallpaper. And the camera is pretty bad aswell. But anyway finally done, well almost.
Just need the new EVGA 3 way V2 SLI bridge, LED's etc. Ohh and I still havent come up with a name yet, really unsure what to name the thing.
System is super quiet and suprising with all the fans pretty quiet aswell, i dont like a dead silent system but its nice. The cards perform amazingly idling at low 20s and running maxed out in the mid 30s overclocked. Love the custom loop so far.
If kaapstad, you could change my ROH MSI 980Ti Gaming 6G to EVGA 980Ti SC Reference. I can post the boxes if needed thanks :).
26 Jul 2015
Damn, that's a big card!
It's taller than my 290X with it's Accelero Extreme IV - but not as long, thankfully.
Hey - I put the spoiler tag on for ya's - at least! :p
Very decent quality - in fact glad OCUK put a more competitive price on it this week - else I would have had to go (begrudgingly) to their more northern competitor, as money is not an object like it used to be for me; (but I'd rather stay loyal, and support them than others tbh).
Caporegime
18 Oct 2002
Ireland
Can people with the msi 6g check their fans when its under load and see if there's any kind of reverberating sound? When mine gets to 60-70% fan speed a kind of odd noise starts to appear sort of what you'd hear if a fan was loose or off balance, kind of like wooping sound that alternates in pitch.
17 Mar 2009
UK
Nothing like that on mine, only the sweet sound of the fans keep the card cool and I even used a rolled up piece of paper while using an aggressive fan profile for benching.
Maybe take out the card and check from every angle you can that the fan while static isn't wonky aka raised on one side to the other.
Caporegime
18 Oct 2002
Ireland
Yeah there's definitely something not right, like it said it only appears at a certain fan percentage onwards and it sounds like something is out of balance or something along those lines. *sigh*. Really not having much luck with gpu's lately :(
17 Mar 2009
UK
Normally I'd say barrel distortion on the lens but you're just confirming what you saw and does indeed look warped.
Good look at mine while installed and couldn't look any straighter, may take them out tomorrow and give it a quick check to be sure. Anything else you want me to look out for I can oblige.
What is the gap like in the middle with the edge of a ruler and how's the other side?
Caporegime
18 Oct 2002
Ireland
Its very bent, apparently its intentional.
http://www.overclock.net/t/1564596/...0-ti-gaming-6g-by-msi-the-bend-is-intentional
http://linustechtips.com/main/topic...i-gaming-980ti-look-like-this-out-of-the-box/
That being said i'm still getting this weird "wooo wooo" kind of sound once the fan hits the 70% territory which is a few minutes into a game. I'll contact ocuk tomorrow and see what they say. :(
Caporegime
18 Oct 2002
Ireland
Yeah mine is bendy too.
Super cool though so haven't bothered worrying about it. Quite a few have noticed this too.
Probably as per design. I'm not looking at it a lot anyway.
Doesn't bother me it's bent as its designed that way apparently. Just can't figure out this reverberation type noise. Everything on the card is tight with regards to fans etc so no idea what's causing it :(.
26 Jul 2015
What about the individual blades on the fans. Can you see any differences that might cause oscillation at higher RPMs?
Caporegime
18 Oct 2002
Ireland
Didn't notice anything when I had it out, the blades are a bit different on the card, some new type of blade beside regular types for better airflow.
2 Feb 2014
London
80%, really nice! What's the stock boost? 1460?
11 Jun 2015
Stock boost is 1455 which I am incredibly pleased with, did a quick overclock, knocked +100 on the core and got 1565 which was stable in The Witcher 3 so I am incredibly happy, I guess I spent my bad luck for the year and finally got something decent!
EDIT: Just went to check my idle temp and its 16 degrees C. Is it just me or does that seem too good to be true?
EDIT2: Just a glitch never mind :D
