"We could not update system reserve partition"
Tried to run the upgrade then planned to do a fresh install
Should I run as admin?
Thanks
There is a workaround. Visit the Windows 10 FAQ (Important Information - Windows 10 Issues)
Can someone test this out for me. Maybe the activations are based around the bios serial number too.
CMD > "wmic bios get serialnumber"
Mine is numbers, 009282741XXX (hidden last 3 digits)
mine just says
SerialNumber
System Serial Number
both blank haha.
can someone tell me why my touchpad scrolling turns off back to default after every shutdown ?
Maybe you switched something off you shouldn't have!
Check the FAQ their is a bit about outlook if its ERROR "0x800CCC13"![]()
