and post above ref Dell and others.
I find the curve makes the extra width feel really natural and more immersive for games. Others have said that it does not work for them when working /surfing the web etc BUT for me not an issue
I'd also stick this in the OP: http://forums.overclockers.co.uk/showthread.php?t=18681881 at least to show how about 50% of the pc gamers and users in general has or is planning to shift to said aspect ratio, and the remaining 50% is just happy with what they have atm (doesn't mean they won't consider 21.9 whenever they'll have to upgrade). Maybe someone could start investing some time and pennies into R&D and bake some more 21.9 panels out of them factories. As others said already we're basically stuck with the only 2 IPS by LG and the single VA by Samsung (on 1440p that is). Little more choice on the 1080p.
Good idea Nexus. I've been lazy with updating the thread I created sorry!
A huge thank you for this reply!
A few points:
- I thought the Dell was 5ms response time? This seems normal for IPS panels and something I am used to, so that's no issue.
- The LG is considerably more expensive than the Dell (£110) which would make it a £350 jump in price, I think I'd be calling myself crazy at that point.
- The real estate would actually be a drop down for me, going from 3840x2160 down to 3440x1440, but I don't think that's going to matter much to me, I find it a struggle to use all my monitor during day to day use as it is.
As for G-Sync and 144Hz, it's something I have never tried which means I have never experienced it, so I'm not sure if they're just bells and whistles that I won't enjoy. I wish there was a type of try-at-home monitor service where I wouldn't have to send them back under DSR or anything!
I've gamed on 60Hz for my entire life, I can't say I have ever noticed a lack of clarity/smoothness or anything along those lines.
Ah well, it's either the RoG Swift or the Dell U3415W, I'm scared of not having enough monitor space so I think I'm going to sway towards the latter![]()
PCM2/badass or anyone else...
I am looking to add a "recommended viewing distance" guide for the 21.9 screens, however, I can't seem to find anything similar to HDTV's calculator for TV's. Any links or even your own suggestions?
I find 70-80cm to be the sweet spot for 29" 2560x1080.
Been using the LG 34um95 for the last year and made up with it.
