Presuming you mean the air intake vents at the top?
Dropped my rad a little from my picture and added some typhoons on the roof to aid in air flow.
Dropping from my 360 rad to a 240 in this case has increased my temps by about 4 degrees in idle (30 now).
Felt a little cool air would help.
Guys on the top panel there are five cut-outs either side, are these cut-outs able to be illuminated from underneath? If yes would 60cm strip be long enough to cover the five slots? Thanks
60 seems a bit long, the case is only 50 deep and the slots take up abot 40.
Easy enough to illuminate just slid the rad tray out stick some leds in and light the darkness![]()
The strips I'm looking at only come as 30cm or 60cm but I guess they can be trimmed anyway.Thanks Rustyone, I'm thinking to have them Red and Green either side to mimic the Port and Stbd navigation lights of a ship for my themed buildThe strips I'm looking at only come as 30cm or 60cm but I guess they can be trimmed anyway.
I'm gonna use Darkside LP rads they are only 27mm I'm also on the hunt for slimline fans, anyone recommend anything other than the Parvum ones they seem to be my favourite atm.
Ahhh tomorrow! Kid at Christmas doesn't describe my excitement.
Can anyone confirm if it's screwed or riveted together?
Scythe Slip Stream 2000 RPM 120mm 12mm thick, there are a few slim fans to choose from.
Sounds like your building a Clyde Puffer, not Para Handy by any chance![]()
If your talking about putting 2 hdds in front of the psu you will struggle. I managed 1 just. My hdd bay is taken up with my pump so no room there for me!
No easy task given the age of her!Cheers matey. Always good to have a tweak with the 'ol rig now and again!
