Win 10 - 3570k - STOP 0x00000124: WHEA_UNCORRECTABLE_ERROR
18 May 2010
London
Received this error last night whilst playing the Witcher 3 on Win 10.
I suspect it's my cpu oc. It has to be as it's the only part of the system tweaked.
However, I recalibrated my cpu voltages back in April. It passes 8hrs of prime 95 and has been gamed on ever since.
It COULD be a Win 10 thing.... but can software or driver cause this? :confused:
The memory dump doest show much other than: STOP 0x00000124: WHEA_UNCORRECTABLE_ERROR.
However the error logs do mention: GenuineIntel_PROCESSOR_CACHE which to me looks like it's the oc thats unstable.
The CPU is a 3570k currently at 4.5Ghz @ 1.35v I think.
Should I go 4.4Ghz @ 1.35v or 4.5Ghz @ 1.36v?
I am already at the 85c thermal threshold.
That is vcore related, either up the vcore or clock it down. I dont know the max vcore for your chip or what your temps are like.
I have had it before where prime95 is stable and a game crashes.
Negligible performance increase going from 4Ghz to 4.5. TBH I would drop it to 4.2/4.3 and get that voltage and temps down.
I would lower the voltage slightly and the speed if you are at the thermal threshold as you mention. What heatsink do you have? Any chance of getting a better one? Might be worthwhile checking the heatsink (rad?) for dust, and maybe even redoing the thermal paste.
I'm running a Noctua NH-D14.
I think it's pretty clear I should lower the clock speed. :(
It's just a coincidence I get my first sign of instability in about 4 months a few days after the move to Win 10.
Under Windows 10 I will occasionally get GTA 5 to crash the system with a clock_watchdog_timeout. My system is stress test stable and I have never had a crash with any other piece of software. Just knock the speed down 1 or 2 multipliers, even just for that game if everything else is fine.
This is what I had as well on Planetside 2 and an undervolted core.
Nudged it up a little more and all was fine.
I just downloaded the Windows SDK which has a debugger and crash dump analyser.
I found something interesting:
ADDITIONAL_DEBUG_TEXT:
You can run '.symfix; .reload' to try to fix the symbol path and load symbols.
FAULTING_MODULE: fffff80138276000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 0
BUGCHECK_STR: 0x124_GenuineIntel
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
CURRENT_IRQL: 0
ANALYSIS_VERSION: 6.3.9600.17336 (debuggers(dbg).150226-1500) x86fre
STACK_TEXT:
fffff801`3a0f8a38 fffff801`3823a94f : 00000000`00000124 00000000`00000000 ffffe000`a794d028 00000000`be200000 : nt!KeBugCheckEx
fffff801`3a0f8a40 fffff801`384c926c : ffffe000`a794d028 ffffe000`a4c92b60 ffffe000`a4c92b60 ffffe000`a4c92b60 : hal!HalBugCheckSystem+0xcf
fffff801`3a0f8a80 fffff801`3823ae3c : 00000000`00000728 00000000`00000000 fffff801`3a0f8e70 00000000`00000000 : nt!WheaReportHwError+0x258
fffff801`3a0f8ae0 fffff801`3823b19c : ffffe000`00000010 ffffe000`a4c92b60 fffff801`3a0f8c88 ffffe000`a4c92b60 : hal!HalBugCheckSystem+0x5bc
fffff801`3a0f8c30 fffff801`3823b088 : ffffe000`a4c8f640 00000000`00000001 00000000`00000000 00000000`00000000 : hal!HalBugCheckSystem+0x91c
fffff801`3a0f8c80 fffff801`3823b2c6 : 00000000`00000004 00000000`00000001 00000000`00000000 00000000`00000000 : hal!HalBugCheckSystem+0x808
fffff801`3a0f8cc0 fffff801`3823b450 : ffffe000`a4c8f640 fffff801`3a0f8ef0 00000000`00000000 00000000`00000000 : hal!HalBugCheckSystem+0xa46
fffff801`3a0f8cf0 fffff801`383ccb7b : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x40
fffff801`3a0f8d20 fffff801`383cc931 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!setjmpex+0x2aeb
fffff801`3a0f8e60 fffff961`1c26f4aa : fffff961`1c26709a 00000000`00000000 ffffd000`2725db80 00000000`00000022 : nt!setjmpex+0x28a1
ffffd000`2725d8c8 fffff961`1c26709a : 00000000`00000000 ffffd000`2725db80 00000000`00000022 00000000`00003dff : win32kfull!xxxWindowEvent+0x159a
ffffd000`2725d8d0 fffff961`1c2661d4 : ffffd000`2725da48 ffffd000`2725c240 00000000`00000000 fffff801`ffffffff : win32kfull!NtUserGetMessage+0x72a
ffffd000`2725da00 fffff801`383cd863 : ffffe000`b043f080 00000051`15d0fd38 ffffd000`2725daa8 00000000`00000000 : win32kfull!NtUserPeekMessage+0x94
ffffd000`2725da90 00007fff`b82efc6a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!setjmpex+0x37d3
00000051`15d0fd18 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007fff`b82efc6a
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: GenuineIntel
IMAGE_NAME: GenuineIntel
IMAGE_VERSION:
BUCKET_ID: WRONG_SYMBOLS
FAILURE_BUCKET_ID: WRONG_SYMBOLS
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:wrong_symbols
FAILURE_ID_HASH: {70b057e8-2462-896f-28e7-ac72d4d365f8}
Followup: MachineOwner
See the part in red. This machine is now running Win 10, having done the upgrade last week.
It says quite clearly DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT. Perhaps then this isn't a hardware instability thing and it's just that it's hit a fault due to no longer running win 8 anymore?
It also references the HAL. I'm no windows engineer but as I understand it the HAL gets built during install of the os. If I've done an upgrade from Win 8.1 to Win 10 then perhaps it's just come across an issue due to the HAL not matching exactly any more, due to the in place upgrade?
It's speculative but I think I will try a fresh install before I go changing my cpu oc. As it was rock solid under win 8.1
on my htpc build MSI H81m-P33 any overclock on win 10 fails to boot past logo screen.
Win 8.1 perfectly fine. my main rig is fine with any overclocks.
Think there may be issues with certain components and overclocks on win 10
not necessarily coincidence, different software can stress hardware differently, thus exposing a problem that never came up previously. The instability may have always theoretically existed but if with a different windows some particular sequence of commands didn't happen then you'd never know so it's like it wasn't unstable at all.
Meh, that was a terrible description, hope you understand what I mean :( been a long day...
I get you! :p
Just had a look in my bios now that I'm at home.
Cpu vcore is set to 1.33v for 4.5Ghz. Under full (prime 95) load it does hit 84c.
Sort of in to minds what to do here.
I'm gonna try 1.34v and see how it goes. I am careful with this PC and I don't really game on it when the ambients temps are high.
Did you check your core temps aswell? My old i5 3570k there would be a 10c difference between the lowist temp core and the highist. So i stopped at 4.5ghz with 1.22v.
Well I bumped vcore to 1.34v and tested small fft and it passed for 1 hour. Within 5 mins of the Witcher 3 it blue screened with the same error.
As this PC was rock solid for the last 4 months prior to Win 10, I'm going to see what a clean install will do.
