- 17 Apr 2011
- In front of my monitor
That's why I ended up losing my 360 rad from the top. Just looked far too busy.
Tried it with just one fan on Fan 1 nothing, it should be able to run a single fan without the Sata power, but with or without Sata power, it does nothing.
Tried 3 Pin and 4 Pin Fans no joy on either hub.
Tried a Modmytoys Hub, it works fine, but offers no control on speed, I run my fans at 800 ish RPM so need to get some sort of controller that is small and can hide in the case![]()
I contacted Phanteks and they are sending me a replacement controller. Hopefully it does fix it.
I actually do think its slowing them down from full speed now but only from say 1600rpm to 1350rpm which is still too fast. Was hoping to have them run at 800-1000rpm.
Finished off building yesterday and I see what you mean now. The 3 fans I have connected to the hub just run at full speed. Admittedly I haven't had time to fiddle in the BIOS, setting up a fan curve. Hopefully that sorts it, otherwise I'll have to look for another controller or one of those PWM splitter cables. Would mean having to swap the fans out for the PWM version of the Noctua's.
What's that big think in the middle with the fan bolted to it.?
If your just using 3 fans a splitter would be fine, just split 2 and take another single cable from your M/Board 3Pin fan will work ok from M/Board, just don't use the CPU header as power.
Sorry who are you asking that to?
Sorry can you explain what you mean?
My board has all 4 pin fan headers so would that mean I couldnt do what your suggesting?
Shame the Black version comes with white PCI slot covers and yet the Gun Metal comes with black...
Ok thanks will give it a go.
The top cover on the Matx version is only vented at the rear and small holes at the side it makes a big difference to temps being fitting. Im not sure if its the same with the larger versions of the case but the front of the top panel has a sealed end but I see no reason why.
I have removed it and you can feel a good amount of air escaping out the front so I think i may mod it alittle to allow air to exit the front also.
During bf4 my cards get to 45-50c which is fine but CPU is running 65-75c at stock 4.4Ghz so dont think I will be able to push the voltage i was planing to through it.
