- 2 Jan 2012
- UK.
Could be BIOS bug with that card,not showing BIOS screens
Any beta bios's on tweaktown?ask stasio
Cheers bud, yeah I put some posts up at Tweaktown.
Last night I was able to get into BIOS and change settings with the SHDD's plugged in. Not sure why it worked, but was able to change settings and save them. Booted into Windows no problem after. I don't know if going into the BIOS the first time (Without SHDD's) enabled something. I did that by unplugging the SHDD's and that worked fine.
Not sure if the drives won't allow enter BIOS post from COLD Boot, but work fine when restarting from Windows so drives are already powered if you get what I mean. With the drives unplugged there are no issues whatsoever so it's def them, happened on GA-X99-UD4 before BIOS update as well, a BIOS update fixed the issue altogether on that board, hopefully this mobo will get fix soon as well.
