OK, Viper it is. Just need a decent build...
At least you knew about them, I ran out of fuel and just died alone...
what's the best way to make money these days? just reinstalling for a quick blast.. I have about 400Mcr to my name, but I haven't played since about March, are people still nailing the luxuries lol? or is it bounty hunting?
Screeeech - Smuggling Imperial Slaves from a power that sells them cheap (Torval) and smuggling to a place that gives higher returns on smuggling (Archon Delaine)
4k per tonne profit.
Best reason to get a fuel scoop is when passing through systems where the nearest station is more than 1,000Ls away - Just takes too flippin' long to divert, refuel and then get back to jumping.No point in scoop now unless going long distance.
I started hitting RES with my new Vulture last night, got 300k in about 20 minutes, was pretty quiet though..
Still, It'll pay for some upgrades....
Was sure I'd seen five the other day... In fact, I know I did. Bunch of Eagles, IIRC.It's only when you're dealing with multiples that it can get a little hairy, which in a typical RES is limited to 3.
Again, beg to differ - NPC Python packing three large Plasma Accelerators, bang bang bang, OMG where's my windscreen gone, boost boost BOOOOOST!!!Anything which does manage to hit you won't be anything to worry about given how tough your shields are.
Python!!!Aye thats the plan until I save up for something else, just not sure what yet... :/
I always thought everything scales up with your combat ranking?
Note I said typical. Not all. Typical RES will have up to 3 hostile ships in one area at a time. Get a good instance and you'll see more. Become hostile to a local faction and you'll definitely see more.
And again you're not quite understanding what I'm getting at. If you're side/vertical thrusting in a Vulture, staying off the centre axis/boresight of your foe, then weapons in a fixed variety (especially PA's) aren't going to hit you, unless you are point blank. The only things which will hit you are gimballed/turreted stuff, which you CAN tank in the Vulture and confuse with chaff assuming you're packing a half decent build.
