Well got em in, fired her up, came up a code 10, me 2nd card had a problem, wasn't powered on (no lights on it, only top one), had the yellow exclamation in triangle, so i installed the drivers, mandatory restart, both came on, powered up, then noticed it had froze on desktop, couldn't move mouse, ctrl+alt+del, nothing, so restarted again, selected the old start windows normally, booted up fine, got the box about Xfire, checked CCC, Xfire enabled, both cards showing, so looks like were on
Top card :-
Bottom Cad :-
Look ok ?
Don't know why its showing a fan speed, as they aint going, which is normal isn't it when below 50 degrees or something ?
EDIT: Btw, i had to dig out another 2x 8-pins from my PSU bag, they are 2x singles, but noticed the ends that connect to the PSU, even though they are 8pin, they have 2 blank, but the normal 6+2 pin is on the other ends, ok ?
Just can't remember if the others are the same, as plugged those ones in eons ago, and plus, those ones have another 6+2 pins on them, so single cabe, with 2x 6+2pins on end.
EDIT: Pic of em in :-
EDIT: (again) 2nd cards fan rpm dial has gone now.
